48 Users Online (46 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 3 | 1 | 2 | 3 Next >>
A parametric curtain panel louver.
You can adjust number of slats and depth & width of frame. Edit the nested slat family to achieve desired look and materials.
3.5 Stars from 7 Votes
25629 Downloads
AGRV_GLAZ-CURT_PanelLouver_嵌版百葉
Metric Curtain Panel Louver (it a panel families) with DIM & Material parameters and dimension Guide
Can be used to create curtain walls quickly and easily.
Visit our website AgileRevit.com for more families
595 Downloads
AGRV_GLAZ-CURT_PanelOperating-Emg_嵌版可開窗-緊急
Metric Operating Curtain Panel Windows (it a panel families) and emergency red arrow with DIM & Material parameters and dimension Guide
Use parameter setting to switch between Casement Awning Hopper
428 Downloads
AGRV_GLAZ-CURT_PanelOperating_嵌版可開窗
Metric Operating Curtain Panel Windows (it a panel families) with DIM & Material parameters and dimension Guide
440 Downloads
AGRV_GLAZ-CURT_PanelWithSpiderA_基本嵌版含爪具A'
Curtain Panel and spider with DIM & Material parameters and dimension Guide (the another type is for corner)
515 Downloads
AGRV_GLAZ-CURT_PanelWithSpiderB-A_基本嵌版含爪具B-A'
2721 Downloads
Air brick curtain wall type 2
4.5 Stars from 6 Votes
Product Version: Unknown
9581 Downloads
Air brick wall type 1
4 Stars from 8 Votes
9615 Downloads
Al-Bahar Panel
Al-Bahar Panel
Al Bahar Tower_ Full Parametric Panel (just set NCP value between 0-1)
4.5 Stars from 13 Votes
22256 Downloads
All Colored Glazings
3 Stars from 5 Votes
11952 Downloads
Bathroom Round Vanity
4 Stars from 25 Votes
124285 Downloads
Brick wall
Brick wall
3019 Downloads
Building Cladding 02
Building Cladding in organic pattern
936 Downloads
butt joint glazing family
this is a window curtain wall panel, so it can be scheduled. you need to bugger around though by adding the conditional statement
if(schedule id = 1,width+frame,width)
if you want the schedule dimensions width and height to be equal to the windows in a combined schedule.
1988 Downloads
Channel Glass
Channel Glass
Curtain panel family based on Pilkington Profilit K22 channel glass.  Set vertical grid pattern to minimum spacing of 9.13in (232mm)
8571 Downloads
Corner column 4 curtain Wall
1653 Downloads
Corrugated Mullion
Corrugated Mullion
This is a profile for a corrugated mullion to make walls with corrugated metals.
To use the file load the profile into the project. Go to mullion and create a duplicate of the mullion and name it corrugated and select the profile you loaded in and set the material you want and click ok. Now Create a new curtain wall set the vertical grid to fixed distance and the spacing to 6-1/2" check the box for adjust for mullion size.
Set the horizonatl grid to none. Set the interior type vertical mullion to the mullion youy made. Now you are ready to draw currgated metal walls.
Renders perfectly and works for walls and roofs.
3.5 Stars from 3 Votes
8780 Downloads
Corrugated Shed
Corrugated Shed
This is a sample corrugated shed using curtainwall mullion to create the corrugated effect.
4685 Downloads
curtain panel
Product Version: Revit Structure 2010
932 Downloads
Curtain Panel Casement window
Casement window, can be inserted into curtain walling
4.5 Stars from 4 Votes
13143 Downloads
Curtain wall muro cortina
5 Stars from 8 Votes
22734 Downloads
Curtain Wall Panel
Gives the choice of choosing either field or corner panel.
Usefull when one wants a structural glazing corner with no mullion.
Also, by clearing both types (corner or field panel) gives an empty panel.
Angle of junction - parametric.
4640 Downloads
Curtain wall panel - Louver
its fully parametric
3 Stars from 4 Votes
8004 Downloads
Curtain Wall Panel - Opaque Parapet
Same as previous Curtain Wall panel, but usable as parapet panels between floors.
4120 Downloads
Curtain Wall Panel Door
Door to replace panel in Curtain Wall
Single Glass Door with frame top and bottom
Pull handle inside and out
4 Stars from 12 Votes
113994 Downloads
Curtain wall panel pattern based star shaped
10695 Downloads
Curtain Wall Panel Sliding Door
Sliding door to fit in Curtain Wall.  Based on Curtain Wall Panel Door by dylan88.
23783 Downloads
Curtain wall panel star shaped
It is perfect for equal sides curtain wall panel because it was designed on perfect shaped polygon
4.5 Stars from 7 Votes
10654 Downloads
Curtain Wall Panel w Louvres
Parametric, to be inserted in a CW.
Number and dimension of Louvres - parametric.
6788 Downloads
curtain wall panel with spider clamp
I found another version of this panel here. I used it to make the clamp smaller.
It adapts to the curtain wall perfectly
8600 Downloads
Page generation time: 0.7684
