Nana Wall WA67 Folding Walls. Default types have been created for both interior and exterior door systems ranging from 2-12 panels. Single panel systems must be created independently since this family relies on a system of arrays. User may create duplicate types and customize door panel configurations using the nested detail component. All configurations listed on Nana Wall's website for the WA67 series have been provided. Elevation hinge lines should be drafted manually in elevation as required. |
21631 Downloads
A revised version of another on this site that had issues when the model was "flexed". Those problems should be fixed in this. |
Product Version: Unknown
4416 Downloads
1 External Lourve Metal Door |
20649 Downloads
Fully parametric. Modeled after the Brannen Millwork Euro Frame door, up to the CAD details. Wouldn't go thinner than 6" walls for the frame's sake. |
29278 Downloads
2943 Downloads
THIS IS TO BE THE 1322 JELD-WEN DOUBLE DOOR WITH 2 12" SIDELIGHTS. I TRIED TO MAKE IT USER FRIENDLY. BUT SINCE I AM STILL LEARNING, I CAN NOT SAY IF IT IS OR NOT. |
Product Version: Revit Building 9
4647 Downloads
16' Overhead Garage Door - Prairie Design |
Product Version: Revit Building 8.1
17803 Downloads
16' Overhead Garage Door - Stockton Design |
19870 Downloads
16' Overhead Garage Door - Wagon Wheel Design |
10683 Downloads
16' Overhead Garage Door - Waterton 1 Design |
10994 Downloads
16' Overhead Garage Door - Waterton 2 Design |
5977 Downloads
16' Overhead Panel Garage Door Colonial |
24934 Downloads
8776 Downloads
A 180 Degree Double Swing door - Parametric |
12695 Downloads
180-degree swing door |
No rating |
10221 Downloads
5596 Downloads
1868 Downloads
No rating |
1770 Downloads
7252 Downloads
Fully Parametric 2 Panel Bifold Door. All components are nested families. Hardware included |
46875 Downloads
Non parametric |
11719 Downloads
Non parametric |
11709 Downloads
Parametric 2 Panel Slide Door with a Flexble Opening Distance Door Panel and a fixed Panel |
No rating |
Product Version: Revit Structure 2020
801 Downloads
No rating |
359 Downloads
No rating |
332 Downloads
This is a 2 way swing door modified from existing library. The user will be able to see the 2D plan swing projection on both interior and exterior of the door. |
15262 Downloads
2 way swing door. change angle of swing |
8474 Downloads
2-Panel- Patio Door |
26719 Downloads
2D swing family for nested in host family.for tutorials please visit https://youtu.be/3yHhADMAhyE
subscribe channel and share to others fo more tutorials |
No rating |
157 Downloads
3 Panel Glass Slider w Trim |
15807 Downloads
