43 Users Online (42 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 21 | 1 | 2 | 3 | 4 | 5 Next >>
1/2" vinyl reveal
Product Version: Unknown
1934 Downloads
1976 Surfer Champ Pinball Machine
I had a go at the pinball machine and got almost everything. unfortunately i didnt workout the playfield so its flat with an image. enjoy
3.5 Stars from 3 Votes
28421 Downloads
1996 Cadillac low LOD
My first car model. might be distored from real life
492 Downloads
3 Stars from 2 Votes
4296 Downloads
2D DRESSER-PARAMETRIC-پارامتریک-کمد و گنجه دو بعدی
2D DRESSER-PARAMETRIC-پارامتریک-کمد و گنجه دو بعدیFOR MAP DESIGN
5 Stars from 2 Votes
446 Downloads
2D RC Column
2D RC Column
This is 2D Rc column family
Product Version: Revit Structure 2013
5656 Downloads
2D RC Wall detailing
This is a 2D Rc Wall reinf. detailing family
3879 Downloads
2D Rebar
2D Rebar
Revit 2017
4 Stars from 4 Votes
4729 Downloads
2D Rebar Bend Types
2D Rebar Bend Types
Revit 2017
2.5 Stars from 3 Votes
3795 Downloads
2D Rebar S Type
2D Rebar S Type
Revit 2017
2 Stars from 2 Votes
2318 Downloads
2D Rebar Ties
2D Rebar Ties
Detail Components Revit 2017
4.5 Stars from 8 Votes
4053 Downloads
2D Reinfocement rebar section
2D detailing reinforcment element
2805 Downloads
2D Reinfocement rebar section (modified)
3141 Downloads
2d sweep profile
2d sweep profile
I'm pretty new on revit families. This is a little profile that you can attach to your wall as reveal to make it look like a corrugated metallic face.
Revit version: 2017
3864 Downloads
2d Tree Plan parametric Detail Item
4.5 Stars from 10 Votes
26661 Downloads
32x96 mahogany wall panel
Panels are designe for a study, library or executive office. Unit comes in white, walnut, and mahogany.  Panel shows framed panels, base molding, and crown molding.  Sorry I have not figured how to cut them to fit specific walls.  However, I created the panels in Autodesk Inventor where you can customized panel above and below windows etc.
1.5 Stars from 2 Votes
3778 Downloads
32x96 walnut wall panel
2959 Downloads
32x96 white wall panel
4772 Downloads
6 inch diameter log
6 inch diameter log
A simple Generic model with options for surface (bark) and end material (tree rings)
1066 Downloads
8 inch mortar joint concave
2486 Downloads
8X16 concrete footer
6472 Downloads
90 DEGREE TURNING CIRCLE PASSENGER CAR
672 Downloads
a plate
Product Version: Revit Building 9.1
1127 Downloads
A307 Bolts-Head.rfa
2634 Downloads
A325 Bolts-Side.rfa
2367 Downloads
A325 Bolts-Side.rfa
1567 Downloads
Access Floor Pedestal - Detail Component
Parametric Detail Component for Tate Access Floor Pedestal
1330 Downloads
ADA Family Restroom Signage
Generic Model Wall Based ADA Family Resroom placard.
4927 Downloads
ADA Grab Bar Shower (Parametric)
Wall-Hosted family.  Curved grab bar for ADA shoower.  Can be mirrored into position if needed.  Fully adjustable w/ pull arrows.
6717 Downloads
Adaptative metal grate. Rejilla técnica adaptativa
Rejilla tecnica adaptativa
2 Stars from 6 Votes
9136 Downloads
Page generation time: 0.6058
