WWW.REVITOBJ.COM
WWW.REVITOBJECT.IR |
No rating |
1182 Downloads
Microwave base |
5981 Downloads
No rating |
Product Version: Revit Structure 2009
3630 Downloads
No rating |
6471 Downloads
A generic wood cabinet with the handles toward the bottom that you can specify to meet you need. You can move the handles and change the material if needed in the family view. |
Product Version: Unknown
29130 Downloads
Vanity bracket that holds skirt |
No rating |
304 Downloads
3 equal drawer base cabinet with height parameter based on revit 4 drawer model. |
14664 Downloads
3 Drawer Vanity Cabinet |
9925 Downloads
1 connected swing-out door with ONE rotating circular shelf
Image is from http://trendkitchencabinets.com/wp-content/uploads/2012/11/Menards-Kitchen-Cabinets-Unfinished-1.jpg |
20178 Downloads
Lazy Susan with 1 connected swing out door and TWO rotating shelves
16023 Downloads
A parametric wall cabinet/ display case with 4 doors. You can change the width, depth, height and materials. The doors will remain equal to each other in size. |
4533 Downloads
Adjust length of leg's 1, 2 and 3, counter depth and thickness. |
Product Version: Revit Building 9.1
6656 Downloads
9438 Downloads
Caster Whell (50mm) for furniture - Revit 2021 |
1860 Downloads
wall based 6ft wide by 3ft high mirror designed for public bathrooms. Default 4ft above floor. |
38020 Downloads
75mm Caster suitable for cabinets etc. |
7879 Downloads
This is based on a Steelcase sink skirt. It is adjustable for width only as a type. You will have to duplicate if you have more than one size in your project. |
6502 Downloads
adjustable display cabinet |
9625 Downloads
Adjustable Double vanity bench top and tops. Not fully modeled. Better be used only in plan and elevation views. |
4412 Downloads
Angled corner cupboard. (Part of the default revit domestic kitchen set) |
No rating |
3682 Downloads
No rating |
1002 Downloads
made at NOHS. appliance garage, kitchen, toaster, coffee machine, cabinet |
7835 Downloads
applience garage made at NOHS by Jack Perry |
No rating |
1409 Downloads
Armário Cozinha, podendo:
-Dimensões, Altura, Largura, Profundidade, Espessura Moldura e Altura do Puxador
-Materiais: Moldura, Porta, Gaveta, Puxador e Tampo Superior;
-Visibilidade do Tampo superior: Caso oculte o tampo, adicionar a Altura do armário a altura que o tampo ocupava.
Visibilidade da Porta: Caso a oculte para deixar visível as prateleiras, oculte também o puxador. A altura do armário, some a altura do puxador. |
1601 Downloads
-Dimensões, Altura, Largura, Profundidade e Espessura da Moldura;
-Materiais: Moldura, Porta, Puxador e Tampo Superior;
-Visibilidade: Tampo superior. Caso oculte o tampo, adicionar a Altura do armário a altura que o tampo ocupava. |
1034 Downloads
-Dimensões, Altura, Largura, Profundidade e Espessura da Moldura e Altura do Puxador;
1530 Downloads
72HX14WX36L |
No rating |
2441 Downloads
Base Cabinet - Open
*** IMPORTANT: The shared parameters file must be pointed to inside Revit. All casework families built by myself can point to the same shared parameter file. ***
- Do not adjust parameters under "Other" category.
- Please save the shared parameters file in the same directory as the cabinet family.
Any comments would be appreciated. |
No rating |
4251 Downloads
Base Cabinet - 1 Door
No rating |
7203 Downloads
Base Cabinet - 2 Door
12394 Downloads
