53 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 12 | 1 | 2 | 3 | 4 | 5 Next >>
11 7/8 inch I-Joist Arrows
3 Stars from 1 Votes
Product Version: Unknown
2897 Downloads
14 inch I-Joist Arrows
1564 Downloads
2-pick Break Line with scaling jog
This is a 2-pick line-based break line symbol.  After you click once to start the break line, an invisible line arrow will appear to indicate which side of the line the mask will be on.  By default it masks on the same side/direction as the exterior side of walls, i.e. outer side of a clockwise loop.
It also has a view scale parameter, which you can enter before you start drawing the break line.  Simply enter the view scale for each break line you draw, and all your break line jogs in your entire project will match size and shape exactly.
Note: the arrow is only visible while drawing the break line, or when you hover the mouse over it or pick it.
5 Stars from 2 Votes
14401 Downloads
2004 Master Format Keynotes
2058 Downloads
2D Closet rod & Hangers
This component is used to put 2d lines in a model for closet rod and Hangers It is parametric in length and easy to pull the ends to the length of the closet.
4.5 Stars from 3 Votes
19584 Downloads
2D Tree Elevation Parametric Scale with Height
2 D Elevtion Parametric Tree : Height Parameter adjusts with width (Scalable)
3 Stars from 4 Votes
6601 Downloads
2X10 floor joist arrows
2187 Downloads
2x12 Floor Joist Arrows
2045 Downloads
2X8 floor joist arrows
1650 Downloads
3D Arrow - 90° - Horizontal
Need to point to something in your 3D enviroment, Come with 3 colours each - easy to add other colours.
1119 Downloads
3D Arrow - 90° - Vertical Down
732 Downloads
3D Arrow - 90° - Vertical Up
1084 Downloads
3D Arrow - Straight Horizontal - Flat
1263 Downloads
3D Arrow - Straight Vertical - Downwards
590 Downloads
3D Arrow - Straight Vertical - Upright
679 Downloads
3D grid intersection w. parametric text
2447 Downloads
9 1/2 inch I-Joist arrows
1297 Downloads
A Room tag displaying department name
This is the modified version of original room tag.
10669 Downloads
A2 STUDENT TITLE BLOCK
A2 LANDSCAPE BUTTOM PANELLED TITLE BLOCK
3 Stars from 2 Votes
7131 Downloads
A3 parametric HEBREW landscape
3651 Downloads
A3 parametric HEBREW portrait
2413 Downloads
A3 PROFESSIONAL TITLE BLOCK
An A3 title block for professional working drawing
3.5 Stars from 6 Votes
19752 Downloads
A3 Titleblock for New Construction (Malaysia)
Modeled in Revit 2024
411 Downloads
A4 TITLEBLOCK
This is an A4 titleblock. For the metric system [obviously] I decided to upload this as I found it difficult to find a l decent A4 landscape title block.
8591 Downloads
ABOVE CEILING DEVICE - AS SHOWN Symbol
Above Ceiling Device As Shown Symbol
930 Downloads
addendum symbol
addendum symbol
addendum symbol
1484 Downloads
Align Symbol
Align Symbol
Align symbol made in Revit 2012 using instance parameters to adjust the depth and width of the symbol. Arrowheads are 1/8" 30degree filled arrowheads.
1373 Downloads
Anno Break Line-Single.rfa
Plan or detail break line symbols.
394 Downloads
Annotation - For Reference Only
Generic Annotation - FOR REFERENCE ONLY stamp
Product Version: Revit Building 9.1
1238 Downloads
Annotation Dimension Family
Dimension family create with Revit 2022
289 Downloads
Page generation time: 0.6639
