86 Users Online (84 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 10 | 1 | 2 | 3 | 4 | 5 Next >>
12" x 24" Tile Pattern (1/3 Stagger Horizontal)
This is a .pat file for a 12" x 24" tile pattern that is staggered by 1/3 each row horizontally.
To use this, download the file and save it to your file directory. Then, in Revit, create a new model hatch. Edit the hatch to be "Custom" instead of simple, and then import the file.
5 Stars from 3 Votes
Product Version: Unknown
8684 Downloads
12" x 24" Tile Pattern (1/3 Stagger Vertical)
This is a .pat file for a 12" x 24" tile pattern that is staggered by 1/3 each row vertically.
4 Stars from 13 Votes
22216 Downloads
12x12 (1/3 offset) running / ashlar
Tile / Flooring Pattern
4.5 Stars from 7 Votes
5753 Downloads
150mm random WeatherBoard siding
3.5 Stars from 6 Votes
7607 Downloads
200 x 100mm vertical tiling
4.5 Stars from 2 Votes
2415 Downloads
24x16 Running Bond Stone
3 Stars from 7 Votes
16348 Downloads
24x16 Stone with mortar
4.5 Stars from 8 Votes
12851 Downloads
24x4 Running Bond Stone
4 Stars from 8 Votes
11192 Downloads
24x4 Stone with mortar
8002 Downloads
28" X 28" Indian tile
1486 Downloads
2x12 Running Brick
2x12 Running Brick
2x12 Running Brick
4 Stars from 9 Votes
11168 Downloads
2x2 Acoustical Ceiling Tile
3.5 Stars from 3 Votes
10235 Downloads
2x2 Acoustical Ceiling Tile - Demo
5889 Downloads
2x2 Acoustical Ceiling Tile - Textured
3.5 Stars from 8 Votes
13237 Downloads
2x2 Brick Pattern
2x2 Brick Pattern
2x2 Brick Pattern
2.5 Stars from 7 Votes
17046 Downloads
2x4 Acoustical Ceiling Tile
4 Stars from 1 Votes
5597 Downloads
2x4 Acoustical Ceiling Tile - Demo
3828 Downloads
2x4 Acoustical Ceiling Tile - Textured
3.5 Stars from 5 Votes
7641 Downloads
2x4 Second Look Ceiling Tile
3679 Downloads
390x90x90 Block Pattern - Model
This is a Model Pat. file I made of the 100 series 390x90x90 Block, with 10mm mortar.
3 Stars from 1 Votes
2347 Downloads
3x12 Herringbone Hatch Pattern
The pattern is currently scaled to 3x12, if you need something larger or smaller change the import scale. For example, a 6x24 tile would be imported at 2.00 scale.
To rotate the pattern to 45 degrees, fill a region then rotate using the rotate tool and then edit the boundaries to fix the edges.
If you are having trouble downloading the file, right click on the page of code and do a save as file. Set the type to all files and change the .txt to .pat. If .pat is already selected you may still need to erase it and type it in manually. If you save the file and it appears on your computer as a text file that opens with notepad, save that file as a .pat file and Revit should be able to import it as a hatch pattern.
5201 Downloads
3x3 grouted brick
3x3 grouted brick
3x3 grouted brick
3.5 Stars from 4 Votes
8658 Downloads
4" Diagonal Striping
I used this to quickly infill areas of paint striping in a parking lot.
2735 Downloads
4x16 Block
4x16 Block
4x16 Block
2.5 Stars from 3 Votes
8643 Downloads
4x16 CMU or Block
4x16 CMU or Block
4x16 CMU or Block
3085 Downloads
4x8 Sheet
4x8 Sheet
Simple 4' x 8' Hatch patten
4794 Downloads
5" Designer tile (.pat) model based tile pattern
5" Designer tile (.pat) model based tile pattern can be used in revit and other supported software.
How to use in revit
1.Copy the text. open note pad. Paste it and save with .pat(dot pat) extension
2. Open material tab then surface pattern then model pattern-- New--load the pat.
1091 Downloads
How to use in revit
664 Downloads
6" Equilateral triangle Model pattern
6" Equilateral triangle .pat file can be used in revit and other supported software.
How to use in revit
2074 Downloads
8x16 block
8x16 block
8x16 block
3 Stars from 2 Votes
7401 Downloads
Page generation time: 16.3797
