This is a Generic Wall based supply Water Valve I made for toilets and sink water supply. |
5854 Downloads
Product Version: Revit MEP 2010
7761 Downloads
1500x535 double end bowl sink with drain board |
11783 Downloads
1800x535mm double centre bowl sink with drain board |
10277 Downloads
Floor-based indoor swimming pool. Rectangular minus one corner, not parametric in any way, made from mixed colour cerami tiles and pre-filled with water. Still learning, but hopefully someone can use it. |
38564 Downloads
Filtrine Model ES-2-RFC-IW - Remote in-wall recirculating chiller/purifier for serving chilled/purified water to multiple dispensers within 10'-100' via recirculating drinking water loop. (2) Gal. storage tank. Serves a population of (100), (assuming 1 qt./day/person typical usage). |
1456 Downloads
Product Version: Unknown
6983 Downloads
Series FBV-3C & FBVS-3C 2-Piece, Full Port, Brass Ball Valves are used in commercial and industrial applications for a full range of liquids and gases. They feature a bottom-loaded blowout-proof stem, virgin PTFE seats, thrust washer, and adjustable stem packing gland, stem packing nut, chrome plated brass ball, brass adapter, and steel handle. Model FBV-3C has threaded end connections. Model FBV-3C-TH has tee handle with threaded and solder connections. Model FBVS-3C has solder end connections. Pressure Rating for 1/4 in. ‒ 2 in. (8 ‒ 50mm) is 600psi WOG and 150psi WSP. 2 1/2 in. to 4 in. (35 ‒ 100mm) is 400psi WOG and 125psi WSP. |
No rating |
1251 Downloads
Series FBV-4 & FBVS-4 2-Piece, Full Port, Brass Ball Valves are used in residential and commercial applications for a full range of liquids and gases. They feature a bottom-loaded blowout-proof stem, chrome plated brass ball, brass adapter, and steel handle. Seats, thrust washer, and adjustable stem packing seal are virgin PTFE. Model FBV-4 has threaded end connections and is NSF & CSA approved. Model FBVS-4 has solder end connections and is NSF approved. Pressure Rating for 1/4 in. ‒ 2 in. (8 ‒ 50mm) is 600psi WOG and 150psi WSP. 2 1/2 in. ‒ 3 in. (65‒80mm) is 400psi WOG and 125psi WSP. |
1257 Downloads
Series LFFBV-4B, LFFBVS-4B 2-Piece, Full Port, Brass Ball Valves are suitable for a full range of liquids and gases in residential and commercial applications. These valves feature an adjustable packing for longer service life, a bottom loaded blow-out proof stem for safety, a fluorocarbon elastomer stem O-ring to prevent stem leaking at installation, and are rated to 600psi WOG/150psi WSP 1⁄4"– 3". |
No rating |
683 Downloads
Series LFFBV-3C-QC 2-Piece, Full Port, Lead Free* cast copper silicon alloy Ball Valves with Quick-Connect Technology are used in residential and commercial potable water applications. They feature a bottom-loaded blowout proof stem, virgin PTFE seats and thrust washer, adjustable packing gland, stem packing nut, chrome-plated brass ball adapter and steel handles. Comes with integral Quick-Connect inlet and outlet connections for fast installation on copper, CPVC, PEX, and PB pipe. |
No rating |
595 Downloads
Series LFFBV-PEX 2-Piece, Full Port, Lead Free* Brass Ball Valves with PEX Ends are designed for use in PEX piping systems. They feature brass PEX ASTM F-1807 end tailpieces for easy crimping into PEX piping systems, a Lead Free* brass body, chrome plated brass ball, virgin PTFE seats and stem packing, and Viton stem O-ring. Pressure Rating is 400psi WOG. Crimp connection rating is 160psi at 73°F (23°C). |
No rating |
367 Downloads
Series LFFBV 2-Piece, Full Port, Lead Free* Bronze Ball Valves comply with MSS-SP-110 and feature a blowout proof stem and virgin PTFE seats. The full port design ensures maximum flow capacity and minimal pressure drop. Lead Free* construction complies with Lead Free* installation requirements. Has threaded NPT end connections. Pressure Rating is 600psi WOG/150psi WSP for 1/4 in. – 2 in. (8 – 50mm) and 400psi WOG/125psi WSP 2 1/2 in. – 3 in. (65 – 80mm). |
No rating |
714 Downloads
Series B6400 2-Piece, Standard Port, Bronze Ball Valves are used in commercial and industrial applications for a full range of liquids and gases. It comes standard with actuator mounting pads and the port orifice ensures minimal pressure drop. Durafill seats, blowout proof pressure retaining stem, and chrome plated brass ball provide lasting service. Pressure Rating for 1/4 ‒ 2 in. (8 ‒ 50mm) is 600psi WOG (non-shock) and 150psi WSP. Rating for 2 1/2 in. ‒ 4 in. (65 ‒ 100mm) is 400psi WOG (non-shock) and 125psi WSP. |
No rating |
708 Downloads
11309 Downloads
20" x 24" Utility/Laundry Sink |
33678 Downloads
Steris Clean-Up Double Sink |
22841 Downloads
Based on Florestone Mop Sink |
6431 Downloads
14x10" bowls x 3 side board 10" |
No rating |
4287 Downloads
Wall Mounted 3" Cows Tongue Wall Drain |
4926 Downloads
I modled this for a project at work it's a Glycol storage tank c/w baffel, pipe connections(top & bottom) and base. It's used in a pharmaceuticle plant. This is my frst upload, feel free to mess about with it and I hope it helps :) |
Product Version: Revit MEP 2013
7057 Downloads
Length: 2950mmHeight: 2170mmWidth: 560mmWeight: 175 Kg (empty) |
No rating |
Product Version: Revit MEP 2018
387 Downloads
Quick-Connect male connectors - polysulfone. 3501B-0806 - 3/8 in. CTS x 3/8 in. MPT 3501B-1006 - 1/2 in. CTS x 3/8 in. MPT 3501B-0808 - 3/8 in. CTS x 1/2 in. MPT 3501B-1008 - 1/2 in. CTS x 1/2 in. MPT 3501B-1012 - 1/2 in. CTS x 3/4 in. MPT 3501B-1014 - 1/2 in. CTS x 3/4 in. MGHT 3501B-1412 - 3/4 in. CTS x 3/4 in. MPT 3501B-1816 - 1 in. CTS x 1 in. MPT |
No rating |
317 Downloads
Quick-Connect female connectors - polysulfone. 3510B-0808 - 3/8 in. CTS x 1/2 in. NPS 3510B-1008 - 1/2 in. CTS x 1/2 in. NPS 3510B-1012 - 1/2 in. CTS x 3/4 in. NPS 3510B-1013 - 1/2 in. CTS x 3/4 in. Closet 3510B-1014 - 1/2 in. CTS x 3/4 in. FGHT 3510B-1412 - 3/4 in. CTS x 3/4 NPS 3510B-1816 - 1 in. CTS x 1 in. NPS |
No rating |
248 Downloads
Quick-Connect stackable hose barb unions - polysulfone. 3511B-1008 - 1/2 in. CTS x 1/2 in. Barb |
No rating |
198 Downloads
Quick-Connect hose barb fittings - polysulfone. 3513B-1008 - 1/2 in. CTS x 1/2 in. Barb 3513B-1412 - 3/4 in. CTS x 3/4 in. Barb 3513B-1816 - 1 in. CTS x 1 in. Barb |
No rating |
227 Downloads
BARS WILL FLEX TO BE PLACE IN PROPER HEIGHTS AND LOCATIONS. |
No rating |
10690 Downloads
An annotated round end stand alaone bathtub. For best results you will need to use the Linework tool to change the lines to "invisible" |
17158 Downloads
No rating |
645 Downloads
Modified 2 basin sink by hjacobs to create a quick 4 basin one. Credit for the original to hjacobs |
7924 Downloads
