Distance from ceiling and materials - parametric. |
59353 Downloads
No rating |
Product Version: Revit Building 9.1
5876 Downloads
Power Transformer designed carefully to siute your project. |
1815 Downloads
1-Gang Outlet (General Usage) w/ electrical conduit connector. |
6206 Downloads
1-Gang Outlet & 1x15A for Telephone (Combined in one plate). |
Product Version: Unknown
4925 Downloads
1-Gang Single Pole Switch (w/ electrical conduit connector) |
8010 Downloads
Edited for particular job configuration with adjustable day tank option. |
Product Version: Revit MEP 2012
8148 Downloads
140 ft tall wind turbine with 100 ft blades |
8723 Downloads
Simple lamp made from an flat surfaces and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. |
3389 Downloads
No rating |
1482 Downloads
This is the corner for the 18x4 wire basket |
Product Version: Revit MEP 2010
1456 Downloads
So I got this object from another user (I think it is japalvarez03's, hope he/she doesn't mind hehe), and edited it to make it three in one: dobule gang outlet, ethernet outlet and TV outlet. The symbols change accordingly. |
No rating |
550 Downloads
No rating |
303 Downloads
2 Tier Glass Chandelier
Lights Only Work Rendered |
22612 Downloads
Duplex Voice - Data Outlet with four jacks. |
No rating |
2146 Downloads
2-Gang Outlet (w/ electrical conduit connector) |
11009 Downloads
2-Gang Single Pole Switch (w/ electrical conduit connector) |
7960 Downloads
Simple lamp made from flat surfaces and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. |
No rating |
2269 Downloads
200AMPSERVICEPANEL WMAST |
3992 Downloads
Pedigo floor pedestal. Two sizes available. |
No rating |
1486 Downloads
This Family combines a fully realistic renderable Outlet and the capabilities of a MEP Family. Each Receptacle can be scheduled and tied to in MEP.
No rating |
2347 Downloads
220 Outlet symbol |
No rating |
4574 Downloads
This Windturbine has been developped for a thesis about the use of the wind into the city. The aerofoil is designed to accerelate the wind into the turbine.
This content was created by David SERERO, CEO of SERERO Architectes, a compgny specialised in architecture. |
No rating |
Product Version: Revit Architecture 2019
285 Downloads
3 lamp strip fluorescent |
No rating |
21383 Downloads
Hi, I have been modelling a couple of objects that I thought I could share with the rest of you.
I drew it in revit 2021, I can export it into an odler version, but I don't have much faith in my skills to do it properly and keep it's materials.
No rating |
2905 Downloads
Chandelier with adjustable height and slope for ceiling. Has 3 individual light sources. User may need to adjust the lighting parameters for rendering. RAC2012 |
33071 Downloads
3 Light Modern Fixture (Works) |
14317 Downloads
Duplex Voice - Data Outlet with six jacks. |
No rating |
1662 Downloads
3-Gang Switch (2 Single Pole Switch; 1 3-Way Switch) w/ electrical conduit connector |
11165 Downloads
3-lamp stainless steel ceiling mounted track light |
47991 Downloads
