(3)2x4 |
Product Version: Unknown
7396 Downloads
(4)2x4 |
3952 Downloads
(5)2x4 |
No rating |
4022 Downloads
No rating |
353 Downloads
Fully Parametric |
14559 Downloads
Fully Parametric |
8743 Downloads
Typical Gable-end Truss w/ top-chord offset to allow for rake extensions. No webs shown (Manufacturer designs that not architects). Variable chord sizing, slope, bearing length & overhang length. See also "06 - Truss - Fink- No Web". |
2512 Downloads
Typical Truss w/out webbing showing (Manufacturer designs that not architects). Variable slope, chord size, bearing length & overhang length. See also "06 - Truss - Fink Gable - No Web" |
No rating |
2253 Downloads
Parametric column base with adjustable bearing, gusset plate, and hole dimensions. |
4249 Downloads
this is a rough attempt at making a 3D bolt with threads. The length is parametrically controlled but the diameter isn't. The # of threads is an array which could be controlled by a formula but I didn't bother. Can anybody make this better? Please advise. |
Product Version: Revit Structure 2011
12087 Downloads
10 equal part with different size cord and web |
Product Version: Revit Structure 2012
9217 Downloads
12 equal part with different size cord and web |
7626 Downloads
Hollow clay blocks |
No rating |
Product Version: Revit Structure 2018
323 Downloads
No rating |
184 Downloads
Fully Parametric Pratt Truss with Vertical End Members. |
Product Version: Revit Structure 2014
15300 Downloads
Parametric base plate for a structural steel column. Plate dimensions and bolt size can be changed. |
7788 Downloads
3584 Downloads
No rating |
1351 Downloads
339 Downloads
Product Version: Revit Building 8
6851 Downloads
No rating |
179 Downloads
250 Grd CHS Beam |
7582 Downloads
No rating |
231 Downloads
These is a 2d Post Tension Cable call out and symbols. Below is a list of the files that are used with it. Please let me know if you see something that would make these better.
PT - Post Tension.rfa is the main file. It's the one will use to place your cable. I have 4 Family Types setup in it. It can be easily changed up to do what ever you need.
PT - Force Tag.rfa is the tag that you need to call out the Force on that Cable. There are 2 types setup here. one for Kips Per FT and one for Total Kips.
PT - Text is used to show the height of the cable. PT-text are just symbols you can place them were ever you need them.
PT - Offset End. I made it up so if i need to work around an opening in the slab. It's still in Beta. It will get you around the opening but you are going to have to work for it. I'm hoping to think of a better way to do it later on.
You will also need to add two Parameters to your Shared Parameters. One called FORCE for Discipline Structural and Type of Parameter Force. The other is FORCE PER FOOT for Discipline Structural and Type of Parameter Linear Force. |
Product Version: Revit Structure 2013
1531 Downloads
No rating |
394 Downloads
3/4" chamfered curb with adjustable width and height |
No rating |
Product Version: Revit Structure 2009
3957 Downloads
Parametric 3/4"Ø A325 Heavy Hex Bolt. Grip is an instance paramter. Based on grip, formulas determine bolt length and weight (shared parameters) which allow for scheduling and more importantly, bolt list with bolt lengths. Parametric void to cut hosted framing. Bolt visibility paramters are also in place plus an instance parameter for a welded nut (moves the washer to the bolt head side of grip) Based on Portland Bolt specs. Revit 2012. |
15765 Downloads
30" Diameter Geopier |
1412 Downloads
350 Grd Gal Tube CHS |
4504 Downloads
350 Grd SHS |
6352 Downloads
