You can adjust number of slats and depth & width of frame. Edit the nested slat family to achieve desired look and materials. |
25595 Downloads
A line based family which is a work in progress, however this is a parametric component that can be graphically shown open or closed |
13724 Downloads
New Mexico style adobe wall |
2364 Downloads
No rating |
1333 Downloads
AGRV_GLAZ-CURT_PanelLouver_嵌版百葉
Metric Curtain Panel Louver (it a panel families) with DIM & Material parameters and dimension Guide
Can be used to create curtain walls quickly and easily.
Visit our website AgileRevit.com for more families |
No rating |
595 Downloads
AGRV_GLAZ-CURT_PanelOperating-Emg_嵌版可開窗-緊急
Metric Operating Curtain Panel Windows (it a panel families) and emergency red arrow with DIM & Material parameters and dimension Guide
Use parameter setting to switch between Casement Awning Hopper
No rating |
426 Downloads
AGRV_GLAZ-CURT_PanelOperating_嵌版可開窗
Metric Operating Curtain Panel Windows (it a panel families) with DIM & Material parameters and dimension Guide
No rating |
440 Downloads
AGRV_GLAZ-CURT_PanelWithSpiderA_基本嵌版含爪具A'
Curtain Panel and spider with DIM & Material parameters and dimension Guide (the another type is for corner)
No rating |
515 Downloads
AGRV_GLAZ-CURT_PanelWithSpiderB-A_基本嵌版含爪具B-A'
No rating |
2715 Downloads
Product Version: Unknown
9572 Downloads
9610 Downloads
VENT BLOCK MASONRY.
ADJUST YOUR OWN PARAMETERS. |
3295 Downloads
Al Bahar Tower_ Full Parametric Panel (just set NCP value between 0-1) |
22206 Downloads
11948 Downloads
11471 Downloads
Here's a parametric wall void which will cut its host wall at a user-specified angle.
niche applications.
modeled in revit 2012. sorry. |
2346 Downloads
Australian Cee Girts - Custom Orb Wall Cladding |
2096 Downloads
Australian Cee Girts - Trimdek Wall Cladding |
No rating |
2501 Downloads
Australian Zed Girts - Custom Orb Cladding |
No rating |
2248 Downloads
Australian Zed Girts - Trimdek Wall Cladding |
No rating |
2040 Downloads
190 & 175 Basebords or Plynthboards |
No rating |
562 Downloads
Baseboard |
No rating |
4131 Downloads
Bathroom Round Vanity |
124247 Downloads
Batten slats for privacy screen/fence/wall |
29230 Downloads
No rating |
176 Downloads
Bloco/meio bloco 8 Furos paramétrico |
1025 Downloads
Fully Parametric Board and Batten generic model wall based family.
Had to fix a few things that were broken. All good now |
No rating |
3247 Downloads
Brick Pilasters and Lower Wall Panel with Metal Insert |
No rating |
2848 Downloads
Fully parameter. |
No rating |
2012 Downloads
Fully parameter. |
2006 Downloads
