58 Users Online (57 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 35 | 1 | 2 | 3 | 4 | 5 Next >>
0850_Window-Single_WIN_WB
This window family has type parameters to drive shim space, frame, mullion, & sash width & depth, glazing unit thickness and materials. Also, wall sheathing location can be set by instance for different wall assemblies, the flange setback will control how far in front of the sheathing the window will project. Lites & transom can be toggled on or off. Also, this family features nested families for picture, casement, awning, gliding, & single hung operation with proper representation in elevation for window, lites, and transoms. This should accommodate a wide variety of window configurations in a single family.
4.5 Stars from 4 Votes
8781 Downloads
1200 x 1800 Arched window with Sunray transum
3 Stars from 11 Votes
Product Version: Unknown
37569 Downloads
1900's Home Window
1900's Home Window
Parametric Height/Width
5 Stars from 2 Votes
7338 Downloads
1X6 window trim
1X6 window trim
1X6 window trim
5220 Downloads
2 Double Hung Windows with Center Post
2 Double Hung Windows with Center Post.  Width and Height are adjustable along with materials.
3.5 Stars from 2 Votes
3331 Downloads
2 panels glass window (Janela de vidro temperado 2 folhas)
Família originária da criada por Winderson Soares Matos
3.5 Stars from 4 Votes
1434 Downloads
2' X 2' Fixed Pane Window
Craftsman touch 2' X 2' fixed pane window
Trim width and color is changeable
Done in Revit 2014
10845 Downloads
2-3060 Single Hung Divided Lite Mulled with 6030 Round Top Transom
Not Parametric.
3.5 Stars from 6 Votes
8533 Downloads
2Bay Wooden Window Frame
Window frame for 2 Single/2Double side hung window leaves+upper & lower  top hung vent leaves, Security grills my also be used. Vent Ht and Low Lite Ht can be set to zero. All dims are parametric. By Er. L.J.Upadhyay. Varanasi India 919919640999
480 Downloads
2x fixed window
2x fixed window
stacked 2 fixed windows. completely parametric. can adjust width  and then height of each
1 Stars from 1 Votes
10080 Downloads
3 shutter Window
3 shutter Window
RESIDENTIAL 3 SHUTTER WINDOW FAMILY
3 Stars from 2 Votes
12905 Downloads
3x2 Wood Transom Window
3 Stars from 1 Votes
15645 Downloads
3X5 WINDOW
3X5 WINDOW
1139 Downloads
4 window
Product Version: Revit Building 9
1427 Downloads
4-Pane Sliding Glass Door
Four equal width panes, Aluminum and tempered glass door. Trim width and projectiion,rail and stile width adjustable. Metric.
4.5 Stars from 12 Votes
64028 Downloads
4-Pane Sliding Windows w/ Double and Quadruple Awning Transom
Aluminum and tempered glass window showing handles. All dimensions and materials parametrized. Metric.
4.5 Stars from 15 Votes
43428 Downloads
4-Pane_Sliding_Windows_w_Double_and_Quadruple_Awning_Transom_4527.rfa
4 Stars from 5 Votes
10616 Downloads
40mm Casement window
this is a 40mm casement window modeled off the Vantage profile, all elements are extruded profiles right down to the neoprene seals, this file is quite large but excellent for showing that extra detail in your project.  I think i've managed to iron out all the kinks, and yes this window is parametric.
3.5 Stars from 7 Votes
22530 Downloads
40mm Double Casement Window - adjustable pane widths
this is a fixed 40mm double casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is fully parametric.  One awning & one fixed pane - both panes have adjustable widths
19895 Downloads
40mm Double Casement Window - even
this is a fixed 40mm double casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is parametric.  One awning & one fixed pane - even
4.5 Stars from 5 Votes
26852 Downloads
40mm Double Fixed Window - Even
4 Stars from 13 Votes
61889 Downloads
40mm fixed window
40mm fixed window
this is a fixed 40mm window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is parametric.
4.5 Stars from 2 Votes
31654 Downloads
40mm Triple Casement Window - Adjustable
this is a fixed 40mm triple casement window modeled off the Vantage profile, all elements are fully extruded right down to the neoprene seals.  This file is quite large but excellent for adding that extra detail to your peoject.  I think i've managed to iron out all the kinks.  This window is fully parametric.  Two awning & one fixed pane - adjust awning window widths in element properties dialogue & this ultimately defines the fixed central pane.
3 Stars from 7 Votes
53880 Downloads
4x fixed window
4x fixed window
stacked 2 fixed windows. completely parametric. can adjust width of each column of windows  and then height of each
14825 Downloads
4x2 Wood Transom Window
4 Stars from 1 Votes
8757 Downloads
4x2 Wood Transom Windows
2 Stars from 7 Votes
15848 Downloads
5'x5' Mullion window
Job specific- not panaramic
1171 Downloads
5x2 Wood Transom Window
7101 Downloads
5x2 Wood Transom Windows
5 Stars from 3 Votes
14325 Downloads
5x5 Mullion Window
5x5 Mullion Window
Sorry, not parametric, but edible....
3473 Downloads
Page generation time: 0.7069
