98 Users Online (96 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 4 | 1 | 2 | 3 | 4 Next >>
12" parapet cap flashing (annotated)
5462 Downloads
3165 Downloads
24" Double Slope Cap Flashing
1598 Downloads
4" Metal Parapet Cap Sweep for 8" Wall
Simple Profile created for a sloping metal parapet cap.  This profile is meant to be hosted on a wall and works well with the wall sweep tool.  It is not parametric though I don't even know if profiles can be.  It hosts at about it's midpoint in height so that it partially goes down to cover the top of the wall and extends partially above.  It is about 4" high on the exterior face and slopes down 1" to the back side.
3 Stars from 1 Votes
8021 Downloads
6" Concrete Curb Profile
This profile may be used to create a concrete curb at sidewalks, etc... It is 6" high but, it can be edited as desired. Use with Host sweep\floor slab edge.
4.5 Stars from 6 Votes
24978 Downloads
AA-Ridge of Roofs
AA-Ridge of Roofs
AA-Ridge of Roofs
5 Stars from 4 Votes
Product Version: Revit Building 8.1
11613 Downloads
Andersen-Casing Colonial Large
Product Version: Unknown
3046 Downloads
Andersen-Casing Colonial regular
3234 Downloads
Andersen-Casing Craftsman Back Band
2232 Downloads
animais
4 Stars from 2 Votes
639 Downloads
Bloco cerĂ¢mico 8 furos - Ceramic block 8 holes
Ceramic block 8 holes for curtain wall - Standard Brazil.
3 Stars from 2 Votes
5481 Downloads
Building expansion joint
Roof to building expansion joint.  Load profle; Create New fascia
Use Roof fascia to integrate work.
385 Downloads
1 Stars from 1 Votes
215 Downloads
CAP
mortar cap for a 8" CMU wall
2239 Downloads
Classical Baluster
Classical Baluster
4350 Downloads
Colour ful Bluster/ Mullion
3.5 Stars from 3 Votes
3956 Downloads
Commercial Gutter
Commercial Gutter
300mm commercial gutter. Adapted from Steel & Tube profile
5909 Downloads
concrete profile
concrete profile
2761 Downloads
coner round over
coner round over
rounded corner profile for sweeps around objects you may need to have a rounded over edge
4630 Downloads
Corner Board 1X8
Corner Board 1X8
Corner Board 1X8
Product Version: Revit Building 9.1
1260 Downloads
cornice
cornice profile
4289 Downloads
cornice 2
cornice profile
2676 Downloads
Cornice Profile Historic 2
Profile of cornice from historic brick building
2016 Revit
4.5 Stars from 3 Votes
12784 Downloads
COVE SWEEP
2074 Downloads
Crash Rail
Crash Rail
my first family from scratch; length can be changed. Based loosely on the CS Acrovyn Crash Rail
1338 Downloads
CROWN MOLDING
CROWN MOLDING
Crown molding for residential or commercial buildings.
4018 Downloads
Crown Profile
Crown Profile
I used this for a sweep on my parapet walls.
4930 Downloads
Curb and Gutter
Use this profile to sweep along a path to model your curb & gutter.
3379 Downloads
curved radius roof
curved radius roof
Curved metal roof, edit be front elevation and radius profile.
266 Downloads
curved radius roof
curved radius roof
146 Downloads
Page generation time: 0.6620
