90 Users Online (89 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Objects
Page 1 of 30 | 1 | 2 | 3 | 4 | 5 Next >>
10 - Perforated Return Grille
The 10 Series Perforated Return Grille is designed to match perforated supply diffusers to provide a coordinated aesthetic throughout a space. Featuring 51% free area, the 10 Series grille maintains low noise and pressure drop in high capacity return applications.
Product Version: Revit MEP 2020
352 Downloads
10 inch U-Trough Auger
3 seperate components
901 Downloads
11 metre transport truck
This is an eleven metre delivery truck based on the other truck found on this website.
Product Version: Unknown
11170 Downloads
1 Stars from 1 Votes
6660 Downloads
12' Big curse Fan
12' Big curse Fan
12' Big Ass Fan.  Don't know parameters well enough to make this fan be variable so if someone is good with doing that be my guest.
2.5 Stars from 2 Votes
Product Version: Revit Building 9.1
10213 Downloads
12' Big curse Fan
12' Big curse Fan
Downloaded this fan and made it parametric.  Original design by JHanby.
Product Version: Revit MEP 2018
2668 Downloads
12x12 Supply Diffuser w/ auto-size connector
Uses IF statements to automatically size duct connector based on CFM. Fully adjustable CFM ranges for 4" to 8" sizes. Use one family with one type, no need to change to a new type with a different connector size when you change CFM. Non-hosted family.
2 Stars from 1 Votes
Product Version: Revit MEP 2012
3824 Downloads
150 - Heavy Duty Louvered Supply Grille
Ideal for industrial applications, the 150 Heavy Duty Louvered Supply Grille features individually adjustable blades spaced on 1.5 in. centers to accommodate large air volumes and provide directional control suitable for spot heating and cooling.
393 Downloads
1991 Volvo 850 lo/mid LOD
More detailed car than 1996 Cadillac
Product Version: Revit Structure 2018
1697 Downloads
838 Downloads
1992 Toyota HiAce mid LOD
Japanese made Toyota HiAce. mid LOD. Improved Level of Detail. Included Inventor and Revit versions
1544 Downloads
1996 Cadillac Brougham mid LOD
1996 Cadillac. still need to work on cabin modelling
1081 Downloads
23/30 - Airfoil Supply Grille
Price Industries Airfoil Suply Grille
The 20/30 Series Airfoil Supply Grille features premium quality, extruded aluminum construction. Individual blades are fully adjustable and the airfoil shape helps to reduce turbulence, leading to low sound and pressure drops.
126 Downloads
24x24 Supply Diffuser w/ auto-size connector
Uses IF statements to automatically size duct connector based on CFM. Fully adjustable CFM ranges for 6" to 15" sizes. Use one family with one type, no need to change to a new type with a different connector size when you change CFM. Non-hosted family.
1 Stars from 2 Votes
4298 Downloads
3 Door Fridge
3 Door Fridge
72"x28.5" Three door fridge for use in a restaurant, and has top for work space.
5187 Downloads
3.5-4 ton Bard Wall Hung HVAC
Bard Wall Hung Unit, modeled with high detail. Does add a bit of MB's to your file. (Extremely Non-Parametric, sorry!)
2362 Downloads
300 - Heavy Duty Airfoil Supply Grille
Price Industries Heavy Duty Airfoil Grille
The 300 Heavy Duty Airfoil Supply Grille is well-suited to industrial applications, with individually adjustable blades and wide blade spacing for maximum free area and the ability to spot heat and cool.
296 Downloads
3D Printer
3D Printer
This is a Dimension sst 1200es 3D printer that I modeled for a project.
Solid, not hollowed.  If you want to make a better screen than I did you are more than welcome to, shouldn't be too difficult.  The screen is a material, not a decal, because I have a long series of issues with trying to make decals work.
10431 Downloads
4 Way Cassette Unit
4 Way Cassette Unit
4848 Downloads
4-6"Ø Engine Exhaust Duct Silencer
1821 Downloads
40ft tall glass elevator
3 Stars from 1 Votes
13034 Downloads
500FF/600FF - Filter Frame Louvered Return Grille
Price Industries Louvered Filter Frame Grille
The filter frame is intended to be incorporated into a conveniently serviceable return air filtration system and is designed for recirculating air systems
106 Downloads
6.6M High Galvanize Water Tank Frame
6.6m kamals high galvanize water tank frame for 2floor structure.
1762 Downloads
60/70 - Airfoil Return Grille
The 60/70 Series Airfoil Return Grille features premium quality, extruded aluminum construction, resulting in clean, crisp detailing to blend with almost any architectural surrounding. The heavy extruded aluminum blades are fixed at a 45° angle for minimal see-through.
160 Downloads
700 - Stainless Steel Louvered Grille
Price Industries Stainless Steel Louvered Grille
The 700 Series Louvered Grille makes uses adjustable (supply) or fixed (return) blades to control airflow and provide a supply or return unit with minimal see-through.
259 Downloads
80 Egg-Crate Grille
80 Egg-Crate Grille
Parametric Return Price Industries 80-Egg Crate
257 Downloads
90 - Heavy Duty Return Gym Grille
The 90 Series Heavy Duty Return Gym Grille features a fully welded border and mandrel tubes that support the blades to prevent damage, making them ideal for heavy duty applications. Available in both steel and aluminum construction with multiple core styles and mounting options, the 90 Series can be customized to suit each application.
74 Downloads
Absorption Chiller - Direct Fired - 380-500 Tons.rfa
Product Version: Revit MEP 2009
1595 Downloads
AC Condenser
AC Condenser
32" x 32" x 26" tall. You should be able to choose materials.
2687 Downloads
AC Ext Condenser
AC Ext Condenser
This is modeled in Revit 2020. It's 32" x 32" x 26" tall. You should be able to choose materials.
Hope you like it.
1013 Downloads
Page generation time: 1.1733
