55 Users Online (52 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:18 PM
Objects
Page 1 of 146 | 1 | 2 | 3 | 4 | 5 Next >>
'Pembroke' Table
'Pembroke' Table
parametric table
3.5 Stars from 2 Votes
6157 Downloads
**UPDATED** [SMEG] - 50's Retro Style Aesthetic
Product Version: Unknown
1755 Downloads
*UPDATE* MODERN GLASS TABLE WITH CHAIRS
GLASS TABLES WITH CHAIRS
3.5 Stars from 48 Votes
131520 Downloads
012
012
http://www.revitobj.com/
http://www.revitobject.ir/
6390 Downloads
01813 Lolita Armless - David Edward
First, thanks to revity city user @clars for uploading this and I used it to modify to armless model in David Edwards 'Lolita' collection. Dimensions pretty much match with original but not parametric. The model has two fabric texture. Modify as needed !!!
21335 Downloads
1 Seat Sofa
1 Seat Sofa
1 Seat Sofa
3 Stars from 12 Votes
39938 Downloads
1, 2 & 3 Seater
1, 2 & 3 Seater
Generic sofa with parametised width and depth etc. Has types already created within the family in order to control the visibilty of either 1, 2 or 3 seater sofa
1.5 Stars from 3 Votes
11808 Downloads
1,2,3 or 4 seats couch
You enter just the width and Revit calculates the number of places and draw  the seat marks. Based on gordvan contribution.
6516 Downloads
4 Stars from 18 Votes
38268 Downloads
10 Simple Chair 3D
10 Simple Chair 3D
Made from 20 mm extrusion with model lines for legs and backrest. Simple chair perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
2.5 Stars from 3 Votes
2608 Downloads
10tons bollard
10tons bollard
1029 Downloads
10x15x10 basic cabana
Basic Pool Cabana
3 Stars from 2 Votes
6328 Downloads
11 67 43 - Billiard Table
Parametric. Types include Standard 7'-0", Standard 8'-0", Oversized 8'-0", Standard 9'-0", and Snooker.  (A revised version of another file on Revit City)
4 Stars from 6 Votes
22496 Downloads
11 Simple Chair 2D
11 Simple Chair 2D
True 2D Metric Mass chair made from flat surfaces and lines. Simple chair perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
11195 Downloads
11' Locker Room Bench
2956 Downloads
12 Seaters Conference table
W488*D122 cm
built in with wire management
3.5 Stars from 15 Votes
37880 Downloads
12 Simple Table 2D
12 Simple Table 2D
True 2D Metric Mass table made from flat surfaces and lines. Simple table perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
3484 Downloads
123_or_4_seats_couch_4553.rfa
4698 Downloads
13 Simple Stool 2D
13 Simple Stool 2D
True 2D Metric Mass stool made from flat surfaces and lines. Simple stppö perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
1358 Downloads
14 Simple Sofa 3D
14 Simple Sofa 3D
Simple sofa made from an extrusion and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
4 Stars from 2 Votes
2483 Downloads
1500wide x 2000m double bed
3.5 Stars from 11 Votes
17972 Downloads
16" FACE OUTS
16" FACE OUTS
16" FACE OUTS
1 Stars from 1 Votes
2087 Downloads
17 Simple Table 2D
17 Simple Table 2D
Simple table made from an flat surfaces and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. The beam is offset to counter line clipping through the table top surface.
2070 Downloads
18 Simple Armchair 3D
Simple armchair made from an extrusion and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator. The beam is offset to counter line clipping through the table top surface.
1937 Downloads
19 Simple Shelf 2D
19 Simple Shelf 2D
Simple shelf made from flat surfaces and lines. Perfect for axonometrics when you don't want to delete a bunch of closely spaced lines in illustrator.
2 Stars from 1 Votes
4987 Downloads
1Wardrobe
1Wardrobe
4 Stars from 15 Votes
48920 Downloads
2 Draw Fully Parametric Filing Cabinet
Visit http://www.urbimrevitcomponents.co.uk/ for access to more free downloadable Revit Components.
Also follow us on Facebook http://goo.gl/xDWne to keep up to date with the latest Revit Component uploads.
urBIM Revit Components
12528 Downloads
2 person rounded desk
Approximately 6' wide, 2.5' deep, height can be adjusted
2982 Downloads
2 Seat computer desk
4 Stars from 8 Votes
35571 Downloads
2'-6" x 3'-0" Photo Frame
2'-6" x 3'-0" Photo Frame with editable Material.
Product Version: Revit Architecture 2019
728 Downloads
Page generation time: 0.7731
