No rating |
Product Version: Revit Building 9.1
1338 Downloads
Product Version: Revit Building 8
6676 Downloads
It's adjustable for distance off wall, height, width, extension above top rung, and bracket spacing. If you make it too short, you neeed to make the bracket spacing smaller as well, or it won't work.
I wanted one that would work for both elevator pits and roof access. Could find one, so I made one. My first parametric family.
9839 Downloads
7591 Downloads
AGRV-HRAL_SeriesA Metal & Glass Railing
# Top mounted railing
# Square glass clip
We proivde 2 type of Railing in RVT : H120,H150
We also create a Baluster using the railing support familt, so you can place it manully.
Visit our website AgrvArchitect.com for more families
Because the rvt file is too big, so I put the file in here :
https://drive.google.com/open?id=1CKVk46r1z5WzRaArsojPdq4J7FlYxU83 |
2393 Downloads
# Side mounted(Hang) railing
# Square glass clip
https://drive.google.com/open?id=19RM4y1Ij2RdJfjGX3faolP220oerv6j1 |
No rating |
1102 Downloads
AGRV-HRAL_SeriesB-Hang-Handrail Metal & Glass Railing
# Round glass pin
https://drive.google.com/file/d/1WmspEAEBWCOp3bQo8pejJEKKaX2DvNDJ/view?usp=sharing
No rating |
1009 Downloads
AGRV-HRAL_SeriesC-Metal & Glass Railing
# Floor mounted railing
# rail support
https://drive.google.com/file/d/1TIqQGfTZHJhLxvAHKhBZwEPG244N61jc/view?usp=sharing
No rating |
1199 Downloads
AGRV-HRAL_SeriesC-Parapet-Metal & Glass Railing
# Parapet(Short wall) mounted railing
# rail support
No rating |
818 Downloads
AGRV-HRAL_SeriesD-Metal & Glass Railing# floor mounted railing# talon supportWe proivde 2 type of Railing in RVT : H120,H150We also create a Baluster using the railing support familt, so you can place it manullyVisit our website AgrvArchitect.com for more families |
2803 Downloads
Product Version: Unknown
8008 Downloads
Non Parametic |
No rating |
Product Version: Revit Structure 2018
741 Downloads
baluster |
10992 Downloads
Baluster - Colonial |
Product Version: Revit Building 6
6968 Downloads
Baluster - SCurve |
5161 Downloads
Baluster Curvo RAC 2011 metal pintura roja |
3137 Downloads
Baluster de Madera tipico con material jaspe precioso, para una baranda tipica |
5140 Downloads
No rating |
8181 Downloads
4596 Downloads
Baluster Wing for stairs on spine. Wing to be used as a baluster on a stairs with 250mm going. spine to be created as a in-place family |
20934 Downloads
Balusterku |
No rating |
2692 Downloads
Fypon baluster hope you enjoy it |
7372 Downloads
8122 Downloads
These family was made for showing barrier cables around a parking deck. |
No rating |
1494 Downloads
1848 Downloads
Slim Bottle Baluster |
No rating |
1053 Downloads
Brise feito em Railings! Como não dar pra salvar em família, fica como RVT!! Largura de 1.70m!! |
2725 Downloads
Cable Railing with flat stock balusters and top rail. Includes angled baluster at corners. 2 options: handrail and guardrail without handrail. It's not a family, it's a project, so you just have to copy/paste the railing into your project. I added a material parameter to the balusters. The materials of the rails can be edited in the railing properties window. |
45137 Downloads
Caged Ladder drawn by Jeff Rath in Revit side exit to the left |
4358 Downloads
Caged ladder drawn by Jeff Rath in Revit side step off right |
No rating |
2331 Downloads
