50 Users Online (49 Members):
Forums >> Revit Building >> Technical Support >> Relocating elevation of building
Is it possible to lower a whole building in relation to the site without individualy changing the levels, which often leads to other problems. Using the relocate function seems to bring the levels with it - ie they do not change. Any help here would be appreciated. (Revit 200.
3 Posts No Rating |
TRY THIS GO TO AN ELEVATION AND CHANGE LEVEL PROPERITIES FROM A PROJECT- ELEVATION BASE TO A SHARED- ELEVATION BASE. BUT AFTER YOU HAVE RELOCATE THE PROJECT.
Thank you - that worked perfectly.
Elevation change of a portion of the building |
Wed, Apr 27, 2011 at 10:45:35 AM
Relocating Project |
Fri, Jun 4, 2010 at 10:57:27 AM
Building Elevation Scale |
Fri, Apr 19, 2013 at 9:24:42 AM
Showing Shadows from a building when the building is behind the elevation line. |
Sun, Jul 12, 2009 at 8:02:41 PM
Elevation Shadow Diagrams |
Mon, Jun 3, 2013 at 12:02:47 AM
Members: | 2056486 | Objects: | 23074 | Forum Posts: | 152326 | Job Listings: | 3 |
