37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> BLACK BARS WHEN PRINTING?
Wed, Oct 10, 2007 at 11:11:59 PM | BLACK BARS WHEN PRINTING?
fab13
Just wondering if anyone can help me? .. when i print to pdf or even direct to the printer, i get those black bars on the top, bottom and sides of my page.. How do i get rid of them ???
thanks
Wed, Oct 10, 2007 at 11:14:49 PM | BLACK BARS WHEN PRINTING?
fab13
sorri by the way im using REVIT 9.1
Thu, Oct 11, 2007 at 12:57:21 AM | BLACK BARS WHEN PRINTING?
KimWong
KimWong Avatar
3 Stars: 2 Votes
Your paper size setting is wrong. If your sheet size is A4, make sure your printer paper size is also A4. That should get rid of the black lines.
G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong.
Thu, Oct 11, 2007 at 1:14:47 AM | BLACK BARS WHEN PRINTING?
fab13
thanks Kim but i just checked those settings, and my page size is A3 , and my PDF print size is A3 ...both correspond.
Any other suggestions?
Thu, Oct 11, 2007 at 3:05:05 AM | BLACK BARS WHEN PRINTING?
fab13
hears an example of what im talking about....
Thu, Oct 11, 2007 at 4:09:01 AM | BLACK BARS WHEN PRINTING?
KimWong
KimWong Avatar
3 Stars: 2 Votes
This is the 1st time I come across a problem like yours! This is new. Must be driving you crazy!
The one I described above is just thin line running across the page.
Tue, Feb 26, 2008 at 10:37:19 AM | BLACK BARS WHEN PRINTING?
bailey5
I am having the same problem, did you ever find a solution?
Thanks
Tue, Apr 29, 2008 at 2:29:05 PM | BLACK BARS WHEN PRINTING?
IronmanCole
IronmanCole Avatar
Yep, I got them too, driving me crazy!  I'm running a student version of 2008 and get a fat black line top bottom left and right whenever I print.  Does anyone know what's happening as checked printer settings and all appears well?  Any advice will be greatly appreciated as I have my final year presentations to give in just over two weeks and unless it's sorted I'll have to ditch Revit and use CAD which I don't wanna do!  Thanks!
Tue, Apr 29, 2008 at 4:28:06 PM | BLACK BARS WHEN PRINTING?
lunchtrayrider
3.5 Stars: 7 Votes
You are using the student version of revit correct?  then you will get the black bars.  The easiest fix is to open the pdf in adobe illustrator and delete the black bar.
I like scooters. and motorcycles.
Wed, Apr 30, 2008 at 3:36:17 AM | BLACK BARS WHEN PRINTING?
IronmanCole
IronmanCole Avatar
Ok that's great, at least I know the reason for the bars now and can work with it!
Thanks so much for the reply, it's greatly appreciated Smile
Cole.
Black Bars when Printing
Mon, Nov 22, 2010 at 6:36:40 AM
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:46 PM
black lines
Tue, Jun 20, 2006 at 12:34:17 PM
Printing Black areas
Thu, May 22, 2008 at 8:51:13 AM
PDF Guidelines
Tue, Feb 18, 2014 at 3:55:00 AM
Page generation time: 0.3468
