21 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> File Corruptions
2 Posts No Rating |
I am using Revit Architecture 2008, and recently have had a rash of element corruptions on four different jobs. These four different jobs are all being managed by the same team. We have many other jobs being run through Revit that are not experiencing the same problems. The files have been able to be fixed by Auditing the Central File after the corruption which will remove the offending elements, but today we got a error message that reads..."File has too many corruptions, call customer support, do not use this file except for backup purposes". Does anyone have a clue as to why this would happen, or have any idea how to track and eliminate corruptions before they happen. Thanks, Aaron Phillips
Edited on: Mon, Aug 27, 2007 at 12:59:24 PM
58 Posts No Rating |
this has been a problem in Revit Architecture 2008. try the latest build, 20070810_1700, this problem seems to have been addressed.
2 Posts No Rating |
Thanks, I have download the install and will be deploying it this morning. I apperciate it. Thanks Aaron Phillips
Corruption Warnings - Revit 2008 |
Fri, Jan 25, 2008 at 11:36:45 AM
CRASHES IN THE LATEST 2008 |
Wed, Oct 10, 2007 at 11:16:17 AM
Shared Parameter File Deleted |
Mon, May 19, 2014 at 11:30:31 AM
how to convert a template to project file in 2012 |
Fri, Aug 2, 2013 at 2:58:22 AM
Model file vs. Sheet file |
Sun, Nov 9, 2014 at 4:54:45 PM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
