40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Is colored text possible?
Wed, Oct 18, 2006 at 6:44:26 PM | Is colored text possible?
vnd
3 Stars: 2 Votes
Is colored text possible, and if so, how does one make a text style in different color?
VND
Wed, Oct 18, 2006 at 7:15:13 PM | RE: Is colored text possible?
framerman
4 Stars: 13 Votes
absolutely. click the text button, before you start to type, select properties, edit/new, create or change the color.
Wed, Oct 18, 2006 at 7:24:12 PM | RE: Is colored text possible?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the Text-->Element Properties just set the Color field to what you want...
Regards,
Chris.
COLORED LIGHTS ARE PRODUCING COLORED SHADOWS!! HELP how do you remove them?
Thu, Jul 21, 2011 at 1:52:08 PM
colored/rendered plans
Fri, Jan 9, 2009 at 5:44:24 AM
Rendering : Colored semi-transparent canopy strips
Tue, Jan 27, 2015 at 4:49:08 PM
exporting to print
Thu, Oct 19, 2006 at 3:10:11 AM
Colored Lines for presentation
Tue, Oct 8, 2013 at 7:09:18 AM
Page generation time: 0.4408
