43 Users Online (41 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> tapewred opening
Wed, May 31, 2006 at 6:46:13 AM | tapewred opening
Will9000
4 Stars: 5 Votes
Hi we are preparing existting drawings of a barn for conversion, the walls are stone and 600 thick, i am trying to show a tapered ventilation slat, i can create the opening using void extrusion, but i dont know what render image i should use, i have tried using glass but that does not seem to work, any ideas please i have attached the file if anyone can help, many thanks Will
Mon, Jun 5, 2006 at 8:07:43 AM | RE: tapewred opening
fazerneil
4 Stars: 4 Votes
get a decent photo of a louvre and add this to a new material and then assign to your infill panel. Alternative, create a louvre window in revit using slats in lieu of glass. May already be one in library.
Mon, Jun 5, 2006 at 8:25:25 AM | RE: tapewred opening
Will9000
4 Stars: 5 Votes
Thanks for your response, but i think you misunderstand my question on plan the opening is tapered and not pararell this is what we are trying to achieve, sorry i should have phrased my question better the opening is open, no frames or anything, the opning is 100mm external and 300mm internal, how do i achive this using the void command as nothing seems to cut out of the wall when i try Will
Tue, Jun 6, 2006 at 2:46:14 AM | RE: tapewred opening
fazerneil
4 Stars: 4 Votes
Sorry Will You have your wall. Create reference plane on face of wall. Go to component and create in place. select element wall. choose void form. Void blend. You are drawing top of void on face of wall so set it slightly off wall face (-20 say) and draw your rectangle/square. Then pick edit top and draw your rectangle/square for the inner face of wall. Again, set your extrusion depth to pass through wall. When happy click finish sketch. go to a 3d wireframe view.select cut geometry from top toolbar and pick wall, then pick void you have just created. Select finish family and you should have an opening through the wall with sloped jambs/head and cill Phew...
Wed, Jun 7, 2006 at 3:56:07 AM | RE: tapewred opening
Will9000
4 Stars: 5 Votes
Fazerneil, Thank you ever so much, I tried using the void extrusion but couldnot work out why it didn't work, thanks again for your post Will
Thu, Jun 8, 2006 at 6:06:36 AM | RE: tapewred opening
Will9000
4 Stars: 5 Votes
Fazerneil, any chance of some assistance on this one again please, I have created two solid blends to form a tapered window opening, please see attached file, the problem i am experiencing now is that the window frame i have created within this wont show up, what can i do about this pleae, Thanks again Wil
Floor and shaft opening issues
Fri, Nov 4, 2016 at 3:41:50 PM
Arched Opening Problems
Tue, Jan 18, 2005 at 5:06:11 PM
Opening cut and Void cut not allowed
Thu, May 2, 2013 at 2:29:16 PM
Floor opening issue
Thu, Sep 29, 2011 at 2:29:40 AM
Placing an opening through a wall 'island'
Wed, Jun 5, 2013 at 4:35:42 PM
Page generation time: 1.0671
