49 Users Online (47 Members):
Forums >> Revit Building >> Technical Support >> Fill Patterns - Rotated
11 Posts No Rating |
I created a mansard roof using solid sweep. Then I applied a revit model pattern - 6" shakes to the roof using the paint bucket command and it shows up rotated 90 degrees. I tried a revit city pattern - does the same. Any way I can change it cannot figure it out. Also I am using revit 9.
Thanks
The tab key is your friend...
In plan tab select one of the lines of the pattern, then select it and use the rotate command...
HTH.
THANKS -
Perpsective Fill Patterns |
Mon, May 10, 2010 at 6:12:50 PM
Fill Patterns |
Mon, Mar 10, 2008 at 6:40:09 AM
create/ convert hatch patterns (.pat) to revit fill patterns |
Tue, Jun 2, 2015 at 11:29:00 AM
Fill patterns, where are they? |
Tue, Mar 31, 2009 at 10:11:29 AM
Wall Fill Pattern question |
Tue, Oct 23, 2012 at 8:39:37 AM
Members: | 2034082 | Objects: | 23010 | Forum Posts: | 152214 | Job Listings: | 3 |
