18 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Text in Window Family
Hello,
Does anyone know how to place 'text' into a window family. I would like an 'F.' to show on elevation for my fixed windows.
Thanks. B
![4.5 Stars: 10 Votes](/images/stars_4.5.gif) |
Create an annotation family (generic annotation is probably best) and then place a Label. Save this family and then nest it into your window family in the elevation you want to see it in.
![3.5 Stars: 393 Votes](/images/stars_3.5.gif) |
Note - The above answer will only work in elevations directly parallel with the window.
Personally, I would create a window tag that reads a property set in the window. Then you could use the tag all feature.
WWHub's suggestion is preobably the better way to go. I didnt even think of the case where you may have angled walls in elevation and still want the text to show for windows in that wall.
Manufacturer's Window Family with text file |
Fri, Mar 28, 2014 at 10:31:58 AM
window frame family + nested window frame fill |
Wed, Apr 12, 2006 at 7:31:30 AM
Text(family #1) not showing after loading into family #3 |
Mon, Jan 19, 2015 at 2:43:21 PM
Window and Door OverView Sheet |
Sun, Apr 16, 2006 at 8:51:46 AM
Replace Dimension w/Text Error |
Mon, Jan 12, 2009 at 9:39:27 AM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
