39 Users Online (37 Members):
Forums >> General Discussion >> Revit Project Management >> Link CAD From Website to Revit Sheet
0 Posts No Rating |
Is there a way to link a CAD file from a website into Revit on a sheet? It has to be linked so that it will update automatically with the changes made to it from the website and it has to be on the website so that it can be accessible for several users to update and edit throughout the design process.
So you do this in CAD now? How?
0 Posts No Rating |
We manage, update, and edit our CAD drawings over Sharepoint right now
Look at how that works for you. When you use an Xref, how is that mapped in the CAD file?
If I'm not mistaken, the file is shared but the mapping doesn't really get you there. I think there would be no difference with Revit. If you can map to the xref in CAD, then you can map to the CAD from Revit.
Are CAD's Xref's automatically changed when the Xref is changed?...NO, the latest is loaded when you open or reload. Same with Revit.
Link CAD, Import CAD in the middle of space |
Tue, Sep 21, 2010 at 3:43:46 PM
SHEET INDEX IMPORT OR LINK |
Thu, Sep 18, 2008 at 7:36:41 AM
CAD inserts appear in as many copies in my manage link view |
Fri, May 15, 2020 at 5:17:44 PM
Insert/Link CAD Advice |
Wed, Dec 21, 2011 at 2:56:22 PM
Links to each sheet in sheet index |
Sun, Aug 21, 2016 at 11:06:31 AM
Members: | 2056454 | Objects: | 23074 | Forum Posts: | 152326 | Job Listings: | 3 |
