24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> provided by vendor - errors?
0 Posts No Rating |
We have 8 files/building drawings being referenced into a separate door schedule file (all Revit 2014). One of the referenced files has the following error when opened, and therefore crashes the door schedule file it is linked into:
"The file contains data of Schema EnigmaSchema, provided by the vendor, that has the same Id as a different Schema already in memory. If you continue, these data will be erased from the file. You should be able to reopen the file with the data intact after restarting Revit. Do you wish to continue loading the file?"
Whether the file is loaded or not, the crashing still occurs. Auditing the file upon opening it also crashes the master file.
Does anyone know what this error means? We've found similar posted questions on other Revit sites, but no one has any answers!
Have you audited these files? (Seperate from any links)
Edited on: Tue, Jun 23, 2015 at 2:14:47 PM
0 Posts No Rating |
Yes, auditing the master file (causing the error) crashes the (master) file; opening it regular (non-audit) it's fine.
Auditing the file the above file is referenced into (door schedule), nothing different happens/opens fine.
You audited it without any links loaded? Correct? If so, then send the file to AutoDESK.
Errors and warnings crashing out of Revit. |
Fri, Nov 10, 2006 at 1:41:53 AM
Rotate Project North results in 100's of errors. |
Fri, Mar 11, 2011 at 2:33:17 PM
Run Time Errors |
Fri, Aug 22, 2008 at 3:16:17 AM
Hardware errors on Windows (WHEA) |
Tue, Sep 13, 2022 at 4:23:38 AM
Creating Revit Families From DWG Blocks |
Sun, Aug 21, 2016 at 8:02:55 AM
Members: | 2056437 | Objects: | 23074 | Forum Posts: | 152326 | Job Listings: | 3 |
