39 Users Online (38 Members):
Forums >> Workflow & Implementation >> API & Third Party Apps >> Wrap Sketch Issue
Our Project - An algorithm for Decal, to detect areas bound by a series of curves, either intersecting or consecutive, using image based approach. We are developing using exponential map algorithm.
The inputs are Poly curves composed by lines, bounding box of all the curves, a resolution of the grid etc. The Output is an array of boundary curves of the single area.
We are facing problems with getting UV values on arbitrary mesh. It is difficult to find problem in input mesh which creates bad Exponential map.
It will be really helpful if anyone will give us any suggestions, snippet of code, any ideas with algorithm to find UV values.
Any help is really appreciated. Thank You in advance.
Is this nonsense to the rest of you?
No clue what this post is even about.
Glad it wasn't just me. :S
"Try not to become a man of success, but rather to become a man of value"
-Albert Einstein |
Wall type wrap |
Thu, Nov 26, 2009 at 3:25:40 PM
wall wrap |
Thu, Feb 4, 2010 at 8:52:22 AM
How to wrap the foundation slab material |
Fri, Aug 6, 2010 at 10:36:30 AM
Wall Wrap at Insert's Head |
Fri, Aug 8, 2014 at 7:04:01 AM
Wall Layer Wrap At Inserts |
Thu, Jun 11, 2015 at 11:10:10 AM
Members: | 2056474 | Objects: | 23074 | Forum Posts: | 152326 | Job Listings: | 3 |
