40 Users Online (39 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Structure >> Technical Support >> Adjustable hole in family slab
Fri, Mar 21, 2014 at 10:02:31 AM | Adjustable hole in family slab
ljw70
I have created a slab family which requires holes in different positions, I want to load the family and then adjust tohe hole position within the model, is this possible i assume im missing something ?
Thanks in advance
Fri, Mar 21, 2014 at 10:08:23 AM | Adjustable hole in family slab
3.5 Stars: 395 Votes
We use a face based family to do this.  It has a void that controls the wxhxd and cuts the host.  When you set the d thicker than the host, it is a hole....otherwise you can create depressions.
Family With Multiple adjustable elements
Tue, Sep 27, 2011 at 8:41:08 AM
Adjustable Planting Families
Wed, Jul 27, 2005 at 3:22:27 AM
adjustable louver frame family
Thu, May 5, 2016 at 2:09:35 PM
Plan adjustable door swing issue
Mon, Oct 1, 2012 at 9:13:26 PM
Nested Door Family w/ Adjustable 3D Swing Angle
Tue, Jul 31, 2007 at 5:34:20 PM
Page generation time: 0.9928
