30 Users Online (29 Members):
Forums >> Revit Structure >> Technical Support >> Modeling component driven by host's parameters??
![gregroberson Avatar](user_avatar/100163.jpg)
140 Posts No Rating |
Is there a way to have a modeling component attached to a family in a project and read the hosts parameters. It it seems I should be able to do it somehow, for example how beams get "held" back from other structural elements.
For instance, If I made a complicated base plate family. Is there a way to attach the base plate component family to the column in a project file. Inside thhe project, specify a shared parameter of the structural column. . . and the base plate family update.
I can get this to work in a column .rfa family, but I would rather not have to building baseplates into the column family.
Any thoughts?
Alternatives to driving parameters |
Sun, Aug 23, 2009 at 2:42:58 PM
Host wall |
Thu, Sep 1, 2005 at 5:10:36 PM
Picking Host |
Fri, Oct 3, 2008 at 2:57:27 PM
How can you place a component's width by picking two points? |
Thu, Dec 22, 2005 at 3:42:01 AM
Cellular beams |
Mon, May 7, 2012 at 5:47:37 PM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
