20 Users Online (18 Members):
Forums >> Revit Building >> Technical Support >> Family appears different in different views.
3 Posts No Rating |
Hello all,
I'm relatively new to Revit, so apologies if this is a really simple problem...
I have edited an existing family, a bed, but now I have loaded the family into the project, it appears correctly in 3D view, but plan view still shows the bed/family how it was before I edited it. I am reasonably sure the issue is something to do with symboic line work being active in the family, but am not sure how to editit.
Many Thanks.
![tanrevit Avatar](user_avatar/186218.jpg)
![5 Stars: 2 Votes](/images/stars_5.gif) |
Hi, as my know. You just finish a haft of work, that is changed object in 3d view. On plan view, sure that all model line, annotation detail line are isolate ( and 3d object often hide) , it must be follow 3d object. Then reload to project.
Hope sure
![teafoe5 Avatar](user_avatar/204239.jpg)
![4 Stars: 47 Votes](/images/stars_4.gif) |
Go into the family and under the project browser open the floor plan view. Once you are in your floor plan view find the symbolic lines and change them. Make sure all of the lines are on in visability graphics in your family so you can see them also.
3 Posts No Rating |
Thanks so much to the both of you for replying.teafoe5 your suggestion was the fix I needed! Cheers.
Structural Column Appears as line |
Fri, Apr 21, 2017 at 2:20:42 PM
Edited Families - Appear different in different views |
Mon, Oct 21, 2013 at 7:55:41 AM
Text (in plan views) on a user-created family element |
Tue, Oct 31, 2006 at 11:19:58 AM
creating different views for a new family |
Sun, Jan 8, 2006 at 12:03:06 PM
appears dim |
Mon, Apr 8, 2013 at 7:15:51 AM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
