38 Users Online (36 Members):
Forums >> Revit Building >> Technical Support >> Curtain panel base component problems
12 Posts No Rating |
Hi to All,
I am currently having problems with applying a Curtain Panel Base component which I have created to various surfaces on a mass I have created. Referring to the attached image, the curtain panel on the left has been applied onto the mass surface without a problem but the surface on the right, you can clearly see the panels on the wall are all over the place.
I have no idea why the components of the curtain panel are not aligned as designed on the surface. Both of the surfaces are almost identical to my understanding therefore i have no idea why it has worked for one surface but not the other.
I've spent a good 2 days trying to solve the problem but to no prevail.
any ideas?
Thanks in Advance.
You can't get it with your file, how others can even without the file?
It must be much easier to get answers if your file attached.
want more?
You can get more tips at Enjoy Revit |
Schedule curtain panel by level? |
Fri, Sep 2, 2016 at 4:40:25 PM
Curtain system panel problem |
Tue, Jul 10, 2007 at 10:08:07 AM
Custom Hexagon Curtain wall Panel problems |
Fri, Sep 25, 2009 at 1:25:51 PM
Curtain Panel Family & nesting solid/voids |
Mon, Mar 7, 2016 at 9:19:15 AM
curtain panel offset |
Mon, Sep 1, 2014 at 4:30:14 PM
Members: | 2056426 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
