12 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Linked revit models across discplines
15 Posts No Rating |
Hey yall,
We have linked our structural consultants file, however on our sheets, their gridlines extend past ours, even when i adjust the crop extent of the view. Is there any way to control the extent of just the linked revit files gridlines?
Do I have to modify structural's revit model to place their grdilines on seperate workset to be turned off when uploaded into our model?
Using Revit '11. Thanks yall.
yes you can do that to turn it off, however you will always do that if you will receive new file from them unless you ask them nicely to do the workset thing before sending out...
or another way, is to control it in VG (custom) inside link file and turn off the grids.
** dont be mad, i dont have much... i am homeless |
You can set up a view template that has their grids turned off and apply it to you view.
ronmalt,
I'm sorry but you are incorrect. Linked model grids can be controlled (on/off) independent of the host model through VG settings. This is best set in view templates but it can be done in indiviadual views. Open the view and goto the VG settings/linked model tab. Change the display settings from host view to custom and you will now see the VG for the linked model. Turn the grids off there.
ohhh im also confused the way i said it..but that is what im trying to say.. go VG and find link and CUSTOM
View Filters and Linked Models |
Tue, Mar 28, 2017 at 7:53:31 PM
Linked Models - Element / Component Identification |
Tue, Dec 7, 2010 at 4:10:55 PM
Temporarily display only analytical model for linked revit models |
Mon, Oct 17, 2011 at 3:21:59 AM
REVIT MEP - Separate models for MEP disciplines |
Tue, Jun 25, 2013 at 1:45:42 PM
Changing Elevation of Linked Revit Models |
Mon, Dec 5, 2016 at 9:27:54 AM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
