53 Users Online (51 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Vertical line in exterior rendering
Thu, Feb 9, 2006 at 3:54:35 PM | Vertical line in exterior rendering
bwillits
I am getting a vertical line on an outside wall (wood siding on wood stud). Any suggestions?
Thu, Feb 9, 2006 at 3:58:23 PM | RE: Vertical line in exterior rendering
arccodex1
3 Stars: 1 Votes
Align the finishes of the two walls that are intersecting and use the join geometry tool. Or use the linework tool to make the line invisible in your 3D view.
Thu, Feb 9, 2006 at 4:21:00 PM | RE: Vertical line in exterior rendering
bwillits
Line only shows in rendering and is a couple of feet away from outside corner. Could it be associated with a wall section? Post edited on 2006-02-09 16:21:32
Fri, Feb 10, 2006 at 10:46:31 PM | RE: Vertical line in exterior rendering
Rythmick
5 Stars: 2 Votes
If you look in the material editor settings you may see under the Tile tab where the X setting is a large distance but not large enough, you might add a bunch more digits - at least a 5 digit number, more will not hurt.
Wed, Feb 15, 2006 at 11:47:58 AM | RE: Vertical line in exterior rendering
bwillits
Both of th above ideas are good approaches, however, I still am not having any success and cannot seem to put my finger on the cause, which makes the solution more difficult. I am a teacher and my students are having the same difficulty, which makes me think it must be in my classroom setup or some of the procedures I am teaching. If there are any other suggestions out there, I would welcome your insight. Post edited on 2006-02-15 11:48:46
Wed, Feb 15, 2006 at 1:40:00 PM | RE: Vertical line in exterior rendering
Rythmick
5 Stars: 2 Votes
I still think it is the vertical tile in the material. Try a 10 digit number for the X Nominal size in the Material Editor. You can also toy with the X Offset parameter in the editor, try moving X in a large negative direction and see if you can get the tile line moved off the house.
Thu, Feb 23, 2006 at 3:29:25 PM | RE: Vertical line in exterior rendering
bwillits
Yes, this works. You have helped me solve a solution which has plagued since version 6. Thank you.
Vertical bracing symbolic line ???
Tue, Jun 4, 2013 at 7:33:50 AM
Wall with exterior vertical battens
Mon, Jun 12, 2006 at 10:23:53 PM
Rendering Images for vertical metal wall panels and standing seam roof?
Wed, Apr 19, 2006 at 9:13:39 AM
exterior elevations and line weights
Fri, Jul 20, 2007 at 12:06:07 PM
Vertical line-based detail component?
Tue, Jun 3, 2014 at 2:30:53 PM
Page generation time: 0.7778
