Forums >> Revit Building >> Technical Support >> Please tell me how to make a 190m block work wall.
17 Posts No Rating |
Does revit 2013 have a Block walls?? all i can see is Cavity and Curtain walling. I am look for 190mm block work wall - there must be such a thing in revit?
You can create any wall type you want. Just click on a wall that already exists and duplicate it then edit the structure.
There is one in your library and you can select one wall, duplicate, then you can change that wall like you want (create new walls)
Oops... teafoe5 was faster than me...
Edited on: Fri, Jul 6, 2012 at 9:52:12 AM
Edited on: Fri, Jul 6, 2012 at 9:52:12 AM"
No in my revit 2013. I am assuming you have loaded a family or something. THe versions of REvit i use has tones of cav and partitions- regular housing, but nothing for high rise flats.
How do i find the materials you have.
I am using Revit 2013 as well, you can create any wall type you want, there are no families to load for this. You can edit your structure and add any thickness you want to it and then add any material to your thicknesses that you would like. Here is a tutorial on how to create walls.
http://www.youtube.com/watch?v=0rkf0wwp3Dw
Edited on: Fri, Jul 6, 2012 at 10:01:22 AM
"No in my revit 2013. I am assuming you have loaded a family or something." - NO, if you start a new project with DEFAULT template you will see that wall, and by the way, WALLS are "System families", you don't have any TEMPLATE to create wall families....
Ok, i have re-started / opened a new project architectural and Construction - it has the same wall type. here is a photo.
I see it in the list. It is a partition.
Can you see now? that's your image.
YUP! :-D
DO i feel stoooooopid! I was put off by the word Partition. Thank you!
Wall Sweep for 2 x 6 Sill and 4" Cap Block |
Thu, Feb 11, 2016 at 9:15:08 AM
Glass Block Wall |
Wed, Apr 20, 2005 at 12:04:41 AM
How to create a Glass Block Wall? |
Thu, Mar 23, 2017 at 6:51:59 PM
13
Cant make editable labels in a title block. |
Fri, Aug 7, 2020 at 1:11:01 AM
CMU Block Modules |
Sun, Sep 12, 2010 at 12:23:36 PM
Members: | 2056516 | Objects: | 23074 | Forum Posts: | 152327 | Job Listings: | 3 |
