42 Users Online (40 Members):
Forums >> Community >> Newbies >> Can't Cut It!!!
67 Posts No Rating |
This is what I did:1) Went into Mass Family (to start a new mass)2) created a sphere3) created a rectangular cube that covers the bottom 2/3 of the sphere (so that you see only the top 1/3 of the sphere popping out of the top cube face)Goal: To cut the sphere so that I am left ONLY with the top 1/3 sphere, i.e. the rectangular cube is gone (and took away the bottom 2/3 of the sphere with it).I have tried the Cut Geometry function but doesn't seem to work. Or I'm doing something wrong. Please help.Many thanksDeeply appreciated.
Yes, what you are doing wrong is your not thinking Revit.
First - do you really want a mass? I build with walls - roof - floors. Revit does too and in most cases, you should think that way so mass is not the first thing to think of.
Second - just use a revolve that is part of an arc. No need to cut geometry.
Thanks for your response.
Sometimes I need to start with a geometric mass in order to get a certain shape, and then from there make the architecture out of it. iI cannot do that if I just start with floors and walls. Like a multi-curved roof or some unusual wall. And by the way, it's fine to think mass with revit because revit can support that kind of thinking. I just need to know how to work with the massing families. In fact it is one of the key items in the advanced revit courses.
Many thanks for your input.
Just a question: did you know you have parameters to create your sphere like you want and don't need to CUT that with a void?
Can't make a Two Cut - Square rafter cut on a roof |
Fri, Jan 14, 2011 at 6:20:30 PM
How to show a 'diagonal cross' when you cut timber beam/plate? |
Wed, Oct 23, 2019 at 8:29:42 AM
5'8" wall will not be cut by cutplane |
Mon, Nov 13, 2017 at 3:49:59 PM
Demo Windows 'do not' cut into Walls. |
Thu, Oct 6, 2011 at 12:25:32 PM
cut plane for stairway representation |
Mon, Aug 14, 2006 at 6:02:35 PM
Members: | 2056420 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
