37 Users Online (36 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Dimensions
Thu, Nov 10, 2011 at 5:50:59 PM | Dimensions
idraw38
Using revit 2011 I get dimensions properly formatted in my basement plan but when I go the first floor plan the size of the ticks marks is about 1/20th the size of the basement and the text is also too small to read?
Thu, Nov 10, 2011 at 6:09:55 PM | Dimensions
itsmyalterego
itsmyalterego Avatar
4 Stars: 16 Votes
Ah -- they're NOT too small to read.  They're exactly the same size.
... if you were to print your views on paper.   You'll find that your first floor plan is at at obscenely detailed scale, such as 3"=1".
Annotations and symbols in revit automatically scale with the view so that all annotations are the same size in the sheet, throughout your set.
Fri, Nov 11, 2011 at 9:29:32 AM | Dimensions
idraw38
The problem was that the view scale was set wrong.
cj
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Isometric Dimensions in Drafting Views (details)
Fri, Sep 28, 2012 at 3:13:08 PM
Changing Dimensions
Mon, Feb 7, 2011 at 9:02:52 AM
Disappearing Dimensions
Mon, Aug 19, 2013 at 12:33:56 PM
temporary dimensions disappeared
Wed, Apr 25, 2012 at 10:37:51 AM
Page generation time: 5.3794
