50 Users Online (47 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Leader length on Tags
Fri, Feb 18, 2011 at 9:15:14 AM | Leader length on Tags
fricharz
Is there a way to control the length of a leader when inserting tags?  I am using a wall tag, when I insert the tag, it is too far from the wall.  The only way I can control the length of the leader is to turn off the leader, move the tag closer to the wall, then turn the leader back on.  Yes, it works, but seems time consuming considering the number of walls i need to tag.
Thanks for the help.
Fri, Feb 18, 2011 at 10:11:04 AM | Leader length on Tags
3.5 Stars: 395 Votes
That options bar will get you every time if you don't look at it.
When you start a tag, there is a switch on the options bar to have a leader or not.  With a leder, there is also a length option.
Got it?
Tue, Feb 28, 2017 at 10:35:04 AM | Leader length on Tags
jarosa
jarosa Avatar
4 Stars: 5 Votes
Oh my. The simple things in life. Thank you WWHub
Leaders on keynote tags
Mon, Mar 27, 2006 at 2:43:01 PM
Revit Dimension Straight Leader Line with Controllable Node at Elbow
Thu, Jul 12, 2018 at 12:32:47 PM
Elevation Tag - Leader Problem
Thu, May 17, 2012 at 5:48:20 PM
How tags attach to elements
Tue, Jul 22, 2008 at 11:20:12 AM
Leader Line Control with Wall Tags
Thu, Oct 29, 2009 at 11:39:29 AM
Page generation time: 0.3791
