45 Users Online (44 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Systems >> Technical Support >> How can I export Revit families
Thu, Feb 17, 2011 at 10:36:48 AM | How can I export Revit families
caveman
How can I export Revit families to 3d .adsk files for use with AutoCAD MEP?
Fri, Feb 18, 2011 at 2:10:52 PM | How can I export Revit families
Eddieboarder91
Eddieboarder91 Avatar
4 Stars: 8 Votes
You dont really need to use the *.ADSK file to go to ACAD MEP, you can export directly to a CAD file by going to the app menu then selecting Export. This will be a static size but so is the *.ADSK file also. No MVparts translation is available.
HTH
Few Notes also:
1. export from a 3D view, plan will only give you 2D elements.
2. try loading the family into a project and export from that 3D view, that way you wont have to clean up if there are any connectors or dimensions shown when exported.
Edited on: Fri, Feb 18, 2011 at 2:12:36 PM
www.allbimallthetime.blogspot.com
http://familyjewels.typepad.com/
Fri, Feb 18, 2011 at 2:17:22 PM | How can I export Revit families
caveman
Thanks, I'll try that.
How to make Families have Solid Material? .stl export trouble
Tue, Mar 12, 2013 at 9:52:34 AM
export radiosity settings and materials to viz
Wed, May 26, 2004 at 2:28:39 AM
Revit Export to 3D .DWG still will not export Ceiling Grid Hatches?
Wed, Feb 11, 2009 at 4:42:25 PM
Exporting from Revit
Wed, Apr 6, 2011 at 10:44:45 PM
Revit Export to CAD
Mon, Jul 21, 2014 at 8:35:51 AM
Page generation time: 2.0104
