51 Users Online (50 Members):
Forums >> Revit Building >> Technical Support >> mass from walls- is it possible?
2 Posts No Rating |
hi i know i can create walls by face- but is it possible to create a mass from a building i create in the regular way?? i only need the the outline of the building so i can wrap it with curtain wall. i really need a solution asap- im an architecture student and its for a new project i got thank you very much
If you have regular walls and want them to be curtain walls, just swap them out. You don't need a mass to use curtain walls.
2 Posts No Rating |
i need the mass for the shape- its can be usfull for so many other things - and i need to keep the walls i already built... so ill ask again- is there a way to make mass out of objects such as walls ?? thank you
No
walls disassociated with mass - can't update walls |
Fri, Nov 2, 2012 at 10:51:18 AM
Tops of the walls applied to mass looks horrible |
Mon, Jan 5, 2015 at 10:45:47 AM
Mass and walls are squiggled |
Tue, May 5, 2009 at 2:23:00 PM
How to attach top/base - walls to mass roof |
Tue, Sep 22, 2015 at 3:18:05 PM
Need HELP creating walls from mass |
Wed, Nov 7, 2012 at 6:35:21 AM
Members: | 2056495 | Objects: | 23074 | Forum Posts: | 152326 | Job Listings: | 3 |
