Forums >> Revit Building >> Technical Support >> converting
Mon, Oct 11, 2010 at 9:26:58 AM | converting
zmurrell
Hi im doing a project of redoing my school the only problem is i need components but I have revit 2005 and theres not many models for that!! Im wondering if there is a way to make the newer components compatible with my older version of revit?? Is there a way to convert the files to an older format?
Mon, Oct 11, 2010 at 9:42:25 AM | converting
3.5 Stars: 395 Votes
2005 Revit????  I don't know what that is.
You can always bring a Revit element or project forward but nothing goes backward.
Mon, Oct 11, 2010 at 11:17:35 AM | converting
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
lol!!! i had to read that a couple times!
zmurrell... if you are in school you can get the student version of revit for free.
Mon, Oct 11, 2010 at 3:04:24 PM | converting
zmurrell
well thats the problem the thing we use that we have at school is autodesk revit 2005  my school is to cheap to get a newer version
Tue, Oct 12, 2010 at 5:48:25 AM | converting
4 Stars: 201 Votes
There isn't any REVIT 2005 only Revit 5, the Revit 2000 series start with Revit 2008 then 2009, 2010 and now 2011.
Tue, Oct 12, 2010 at 7:05:20 AM | converting
Show Alabaster's post to your school.  As he said, your school can get all the software for free ... but they need computers that can use that software.  That may be your problem. From 2009 and up, you should have 4Gig of memory on your system.  The last Revit product that worked well with less memory than that was 2008.
converting masses?
Wed, Nov 22, 2006 at 2:48:08 PM
Any known problems converting projects to 2009 form 2008?
Thu, Aug 21, 2008 at 5:49:13 PM
Converting DWG materials to Revit Materials
Thu, Sep 13, 2012 at 3:50:29 AM
Converting !
Mon, Oct 7, 2013 at 1:35:46 PM
converting revit sheet to image
Sat, Mar 23, 2019 at 10:44:30 AM
Page generation time: 0.2846
