26 Users Online (25 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Spiral Stair Baluster Problem
Fri, Feb 26, 2010 at 2:41:28 PM | Spiral Stair Baluster Problem
MattRoyce
I can't seem to get the balusters to touch the treads.  I've tried the Edit Baluster Placement menu and chaning the offsets, but nothing seems to work.
Any ideas?
Thanks
Fri, Feb 26, 2010 at 3:34:27 PM | Spiral Stair Baluster Problem
3.5 Stars: 395 Votes
Goto the on-line library and look at the sample projects there.  They have spirals with railings that work.  BTW - 2010 is no longer posted so look in the 2009 library.
Fri, Feb 26, 2010 at 3:49:02 PM | Spiral Stair Baluster Problem
erland73
erland73 Avatar
4.5 Stars: 85 Votes
Pick the baluster, go to Properties-->Edit/New and change baluster offset to 0'0".......
Fri, Feb 26, 2010 at 3:53:38 PM | Spiral Stair Baluster Problem
MattRoyce
Thanks, the online library railing works perfectly
Residential Spiral Stair
Mon, Feb 16, 2015 at 10:02:06 AM
Stair with Spiral Wall raling
Fri, Sep 28, 2007 at 12:47:22 PM
spiral stair needed, please.
Thu, Jul 5, 2007 at 5:38:38 PM
Spiral Stair I Need to start at 90 degrees and end at 90 degrees [ 1 2 ]
Wed, Feb 19, 2014 at 12:40:38 PM
15
Spiral Stair
Wed, Aug 4, 2010 at 12:08:53 PM
Page generation time: 0.7884
