28 Users Online (26 Members):
Forums >> General Discussion >> Wishlist >> Multi-profile Sweep
98 Posts No Rating |
Alright, here's another one: a sweep that has one path but lets you add multiple profiles to it. I frequently create objects from sweeps that have the same path and have to copy and change the profile for each part, and then if I need to change the path I have to do it as many times as there are profiles in the family.
Why don't you copy clip the path and paste it back for each sweep.
That's what I currently do, but as I said, if I need to make a change to the family and it has 3 sweeps then I need to change the path 3 times. If it was a multi-profile sweep I could change the path once and have all 3 profiles follow it. Sort of a special case wishlist item, but I guess I was curious if others could see it as being useful too.
If you use Revit 2010 with the new "Conceptual Mass" you can create that kind of "Shapes" you need...
Complex profile sweep |
Fri, Feb 6, 2009 at 2:08:35 PM
12
Custom profile for wall sweep |
Mon, Jul 1, 2013 at 2:06:01 PM
11
profile sweep help |
Mon, Sep 21, 2009 at 4:48:04 PM
Sweep profile rotates |
Tue, Oct 23, 2012 at 2:37:24 PM
C-Channel Profile sweep issues? |
Fri, Apr 29, 2011 at 11:47:24 AM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
