60 Users Online (59 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Wall based casework families
Mon, Jan 4, 2010 at 2:31:38 PM | Wall based casework families
revitdude
Happy New Year! There is an issue I’m having trouble with, wall based casework families… There is an automatic elevation constraint that shows up, once load in to project?This parameter does not show up in the family editor, only in the project and to the bottom of casework.  Has someone found a way to access this info, or is it just a system family that can’t be modified.Check it out with a new family wall based or existing component.Thanks, RevitDude
Fri, Jan 8, 2010 at 8:54:54 AM | Wall based casework families
revitdude
I found a solution to my issue, with the elevation being to the bottom of the casework?
In the family editor go to any of the elevation views and select the top ref. plane... right click > element properties > under other > click the bottom box which defines origin, make sure it has a check mark that selects this option...
Thanks...
Nesting Casework Families a Kitchen Family
Mon, Sep 12, 2011 at 3:55:51 AM
Casework Doumentation
Mon, Jan 15, 2007 at 12:21:45 AM
Change casework height based on countertops height
Tue, Jan 3, 2012 at 1:19:43 PM
Casework Graphics
Thu, Aug 18, 2011 at 3:53:04 PM
Scheduling Problem with Face Base Families
Tue, Jul 15, 2014 at 8:59:16 AM
Page generation time: 3.4759
