34 Users Online (33 Members):
Forums >> Revit Building >> Technical Support >> Help Room Filetring Shcedule not working
18 Posts No Rating |
I have a Room Schedule that I want to Filter by the room name. The problem is that I want rooms containing "toilet", and rooms containing "Bathroom" to apear in my schedule. If I do first the Filet by "Toilet" and in the other field I filter by "Bathroom" Revit Is looking for a room Name containing this two words at the same time. Any suggestions? Thanks!!!
10 Posts No Rating |
To my knowledge there is no "AND/OR" condition within the Revit 2010 schedule interface (which is what you are looking for). So, my advice would be to set the department value of the rooms labelled "TOILET" and "BATHROOM" to something like "RESTROOMS". Then you can create a room schedule (make sure to include the department variable as a field) , filter by department (where department is equal to RESTROOM), and then simply set the "department" field to "Hidden Field" under the "Formatting" tab. This will show only the rooms you want. Clear as mud?
Thanks! That is what we ended up doing I just can't believe you cant use conditions in schedules like that!! Thanks again for your time.
room bounding not recognizing room separation line [ 1 2 ] |
Thu, Aug 18, 2016 at 10:02:14 AM
16
Room schedule input when working from an Architectural linked file |
Wed, Mar 26, 2014 at 3:38:18 PM
Room Data Sheet (inc furniture and doors) using a Room Tag |
Fri, Jan 20, 2012 at 9:47:21 AM
Can't create room name in revised room |
Fri, Jun 24, 2016 at 7:21:10 AM
To Link or to group room types? Which is the best way to go? For Hotel room type |
Mon, Apr 28, 2008 at 4:42:21 PM
Members: | 2056426 | Objects: | 23074 | Forum Posts: | 152325 | Job Listings: | 3 |
