46 Users Online (45 Members):
Forums >> Revit Building >> Technical Support >> Error while rotating the truss family
Hi, I am trying to rotate the truss but it gives me error that "CANT ROTATE ELEMENT INTO THIS POSITION". Find attached the snapshot for more details. I have created the truss thru solid modeling using family template - COMPLEX AND TRUSSES.RFT Any suggestions
Now on the implementation stage.... |
I got the answer..... Thnx everyone
Whenever you can, try to post your own responses, so other with the same problem can also learn......
I used BEAMS AND BRACES.RFT template instead of COMPLEX AND TRUSSES.RFT. It works fine then....
Truss - Rotating |
Thu, Feb 6, 2014 at 9:10:40 AM
Truss overhang help |
Wed, May 23, 2012 at 8:32:23 AM
Problem with Truss Family |
Fri, Sep 25, 2009 at 7:34:32 AM
Truss family |
Tue, Oct 16, 2012 at 7:20:05 PM
Truss steel system family creation |
Mon, Oct 19, 2009 at 4:27:52 PM
Members: | 2056495 | Objects: | 23074 | Forum Posts: | 152326 | Job Listings: | 3 |
