18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> Displaying a Stud wall
2 Posts No Rating |
I am extremely new to Revit, so I apologize for the newbie question. Could someone explain how to display a stud wall. How do you display a wall to show the studs? Is it possible to show a wall with one side with sheet rock, and the other open?
Thanks,
Tasse
Studs are not generated automatically in revit...
Typically you would just display a thickness of wall that represents the stud. If you actually want to see the studs then the first question i'll ask is how large is the project as if its too big i wouldn't be modelling them...
2 Posts No Rating |
I'm working on a basement project. It's a fairly small job. What I would like to do is display the stud wall, and then have the option to display sheet rock. I was told you can do this in ADT. Do you know if this is a true statement?
Post edited on 2005-07-14 08:04:26
I Don't know anything about the capabilities of ADT.
If you model the studs in revit then have a seperate wall for the sheet rock you'l be able to turn each off as required...
Stud wall family help PLEASE.... |
Fri, May 9, 2008 at 1:09:58 PM
Wood Stud wall |
Thu, Feb 12, 2009 at 9:05:51 AM
Stud Wall-Make finishes disappear |
Fri, Jan 30, 2009 at 5:24:09 PM
Single Timber stud to double stud wall doesnt wrap the plaster at the end. |
Wed, Aug 8, 2012 at 5:18:19 PM
Revit 2012 - Where have my stud wall lines dissappeared to? |
Thu, May 3, 2012 at 12:57:17 PM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
