Forums >> Revit Building >> Technical Support >> Transfer Section Types does not work
Tue, Mar 17, 2009 at 8:28:29 AM | Transfer Section Types does not work
christophercarlsson
Hi!
I'm trying to transfer some Section Types from one project to another, but I can not get i to work. I have a set of Section types which have different heads and tails, but when I use Transer Project Standards nothing transfers. I get all the heads and tail families loaded, but not the Section Type with its settings.
Am I missing something?
 RA2009
Thanks
Wed, Nov 11, 2009 at 11:10:20 PM | Transfer Section Types does not work
3ab8ari
Did you open a ticket with Autodesk ? Or at least email Harlan Brumm in his Revit Clinic blog....
I usually do such transfers late at night when no one is in the model, to make sure it does not corrupt models with too much crap to to sync, and also to make sure everything is relinquished..... to check, open workset window, and check the "Project Standards" box at the bottom.
Section types
Tue, May 9, 2006 at 12:45:52 PM
Transfer Elevation View to a New Project
Fri, Jun 10, 2011 at 7:36:27 PM
Changing line types and styles in cross section views, wall types etc...
Wed, Apr 12, 2006 at 12:52:32 AM
Masking Revit Does Not work in plan but does work in section
Fri, Nov 13, 2015 at 6:49:21 PM
Templates
Mon, Dec 10, 2012 at 9:39:20 AM
Page generation time: 1.0743
