18 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Perplexing Family Problem...Please help!!
42 Posts No Rating |
I have a family of a bench, or church pew, that seems to have a reference somewhere about 30 feet away from the object. This makes it extremely difficult for me to work with the object in my project. Could someone please take a look at it and try to help me resolve this pesky issue. You'll have to load it into a project to witness it - the mouse will snap to a reference 30 some feet away...I don't know how or why this happens. Thanks in advance! Rafe Revit 2009
well, i don't see any problem with this...
When you build a furniture family, it has a left/right center plane and a front/rear reference plane. That is in effect your reference point for your rotate, array etc. commands. These reference planes are missing in your drawing and the actual pew is 34'-8" to the left and 8'-6" in front of this reference point. That is why when you insert the family, your reference point is so far off. You will need to get your componants and references lined back up with the center of your drawing for it to act like you want it to when inserted in your project. To see what I am talking about, open a new family and your pew family. Select the pew from your old drawing and then paste aligned into the new family. You will see where it lands in your new family. If you get this back aligned with these planes, then it will act right.
stanmpd
Belz A&C
Memphis, TN |
I can also add to that the reference plane property 'Defines Origin'. Although not the direct problem in this particular case it can be the culpret of similar problems. . As well as the Center Left/Right and Center Front/Back reference planes, if you click on a reference plane and click the element properties button you will notice a check box for 'defines origin'. The 'intersection' of two reference planes that 'define origin' is the Base Point (0,0) of the family. When you insert the family into your project your cursor sits at this base point.
I tried to re-define that on his file with his existing reference planes and for some reason, it did not re-define the origin. Not sure what's up with that. I haven't run across that problem very often.
stanmpd
Belz A&C
Memphis, TN |
In place family materail Problem !!! |
Wed, Feb 12, 2014 at 7:53:30 AM
Rendering problem with Custon Family |
Tue, Mar 11, 2008 at 6:49:58 AM
Problem when designing a family |
Fri, Feb 10, 2017 at 12:42:44 PM
problem with a door family |
Wed, Oct 27, 2010 at 1:19:38 PM
Problem with revit family (attic stairway) |
Sun, Aug 31, 2014 at 1:03:43 PM
Members: | 2026013 | Objects: | 22991 | Forum Posts: | 152208 | Job Listings: | 3 |
