41 Users Online (40 Members):
Forums >> Revit Structure >> Technical Support >> Run Time Errors
5 Posts No Rating |
Hi Iam recently having a problem with runtime errors crashing renders i am doing this seems to happen no mater what resilution i set the render at, has anyone encounted these problems before and is there a solution In general i am finding the rendering prosess of 2009 to be very unstable !!
Hi, i had this problem before but now i don't have anymore, you must see several things: Did you upgrade for SP1 (Web update........ 1900) your revit? what is the caracteristics of your machine? I did the upgrade the "Service Pack" 2009, i have a Dual-core 2.4ghz with 3Gb Ram, ATI Radeon 1600 512MB, Windows Vista 64Bits and now i don't have anymore this issue, also, i install "SMP SEESAW" and when i have several programs open at the same time Revit making render, Rhino, Autocad, internet, photoshop, and so one - (at the same time)) i run the SMP SEESAW and isolate Revit to work in CPU 1, the others programs goes to the other CPU....
Edited on: Wed, Aug 20, 2008 at 3:49:54 AM
5 Posts No Rating |
Thanks Typhoon got hold of a service pack and switched on a 3gb switch and the renderings came out without crashing
You Welcome, good for you..
Unknown Run-Time Error (Revit to Robot) |
Mon, Dec 27, 2021 at 2:24:48 PM
Syncronization Issue |
Tue, May 28, 2013 at 12:39:36 PM
Errors and warnings crashing out of Revit. |
Fri, Nov 10, 2006 at 1:41:53 AM
REVIT 2015 Stair - Straight Run to Curve Run |
Thu, Dec 4, 2014 at 11:06:59 PM
Triple Run Stairs 2008 |
Tue, Jul 24, 2007 at 9:03:44 AM
Members: | 2056467 | Objects: | 23074 | Forum Posts: | 152326 | Job Listings: | 3 |
