51 Users Online (49 Members):
Forums >> Revit Systems >> Technical Support >> Select by Element
7 Posts No Rating |
Hi. I'm using Revit Arch 2008. Can you access a list of elements in your project and then select the element by name? Thank you. Please respond. P.S. In 3DS Max, it is called a "select by name" button.
If what you are looking for is a family, there's a subfolder called Family in your Project Browser (Bottom part) that branches to all the families in your model. You can select the name (if you know it) and right click and select all instances.
Motto: "No Post left behind" |
7 Posts No Rating |
Thanks. That helps. When I export the 3D building as a dwg file, names are associated with every element: Curtain Wall Mullions <Rectangular Mullion : 2" x 8" rectangular> Doors <Single_Door_w_Vision_Lite_-_HM_DW_Frame_4849 : 36" x 96"> Glass Lighting Fixtures <Suspended Linear 1 : 48">
Select only required elements |
Thu, Jul 17, 2008 at 2:10:18 PM
Can't select elements like in 2011 |
Wed, Jun 22, 2011 at 8:19:09 AM
how to select an element while Window form is running |
Tue, Jul 15, 2014 at 10:51:01 PM
Wierd Hatch Orientation on In-Place Wall Sweep |
Fri, Nov 4, 2005 at 3:00:26 PM
Deleting an element within 3D environment doesn't delete the element from the 2D |
Tue, Jun 26, 2012 at 1:35:59 PM
Members: | 2056527 | Objects: | 23074 | Forum Posts: | 152327 | Job Listings: | 3 |
