42 Users Online (40 Members): Show Users Online - Most ever was 626 - Mon, Jan 12, 2015 at 2:00:17 PM
Forums >> Revit Building >> Technical Support >> Above level line
Thu, Jun 12, 2008 at 4:23:54 PM | Above level line
horicolonoma
Hi, I am quite a noob with Revit but it's going ok...
I don't seem to figure out how to find the upper invisible lines in my plans...the following image should make it clear.
So the problem is that I don't see the lines above the plan that are cantilevered. I tried to look in the view properties but alas. And I don't know a search term for this in the help file!
Plz have a look at the attached file...
Thu, Jun 12, 2008 at 4:24:43 PM | Above level line
horicolonoma
I made this scheme in Autocad but I would like to find it in Revit...
I have Revit 2009
Thank you
Thu, Jun 12, 2008 at 4:32:56 PM | Above level line
4 Stars: 201 Votes
Hi, in plan view go to VP and in "View Range - edit" you can change The "Top, Bottom and Cut Plane", i think that's what do you want or need.
Thu, Jun 12, 2008 at 5:07:04 PM | Above level line
horicolonoma
Thanks for the fast reply...I tried the VP but no change is made
So if my cantilevere object is on level 2 and I want to see a dotted line on level 1 what should be the top value then?
I tried to attach a RVT file but too large
Thu, Jun 12, 2008 at 5:09:25 PM | Above level line
horicolonoma
Thanks for the quick reply! Good forum!
OK here is a basic Revit file with a cantilevered roof.
on Level 1 I cannot see any reference to the cantilevered roof. So, I would like to have a roof view but in plan and hashed...do you understand?
It's difficult to explain...But I think the picture and this file will make it more clear.
I played with the view settings...but it didn't work out. If you can do it with the view settings, plz post the file back...
THANKS
horicolonoma
Hmmm I tried that out but no...
Plz have a look at the following file: on level one I don't see any reference for the cantilevered roof...
Thu, Jun 12, 2008 at 9:01:53 PM | Above level line
mhans
3 Stars: 10 Votes
We expect in Revit that all elements that are drawn above the cut-plane should project a hidden line on the plan that we are looking on, which is the ideal way to look at things. Roof, canopy, cantilever floors/slabs. header, drop beamza should cast a hidden line projection below. This is not true in Revit. Sometimes you can do underlays, but most of the time you have to trace it by yourself using a detail line.
Motto: "No Post left behind"
Fri, Jun 13, 2008 at 8:20:37 AM | Above level line
horicolonoma
So this is a problem concerning a good program concerning Revit!
Thanks for everything
Fri, Jun 13, 2008 at 12:43:59 PM | Above level line
mhans
3 Stars: 10 Votes
Not actually a problem. We always do have to draw those hidden/overhead lines with our 2d/3d software before. Revit is open to wishlists, and one of these days, these can be a reality. For now, discover things as work arounds.
Fri, Jun 13, 2008 at 4:51:05 PM | Above level line
4 Stars: 201 Votes
No "Horicolonoma", it's not a problem, "MHAMS" has right, Revit is not a 2D program, it's a "BIM", but also it's a "2D" drafter program, (more Amator - depend the practicis), my opinion is if a have this kind of issues i think it's better and quick to do in AUTOCAD, i'm not so Radical to defend Revit with my "life", if i can do this much faster in CAd then Revit i do it in CAD, because TIME iS MONEY, so...
I think we just have to be intelligence to decide what is the best solution to us... if i spend less time to do this in CAD to finish my work and solve the problem to client, i decide to take the obvious....
I'm no't like a "Fundamentalist..."
Edited on: Fri, Jun 13, 2008 at 4:52:21 PM
Revit 2009: Creating customs Level Head: Problems with lineweight (line styles)
Thu, Jul 17, 2008 at 8:09:45 AM
Hiding pieces of a Level Line 2008
Mon, Jan 28, 2008 at 10:54:49 AM
tURING OFF LEVEL LINE IN ELEVATION/SECTION
Sat, Mar 9, 2013 at 9:14:31 AM
Basement Datum Level Line: Now you see it, now you don't
Fri, Nov 18, 2011 at 11:41:49 AM
Control elevation view - level line
Sun, Apr 2, 2006 at 10:26:29 PM
Page generation time: 0.7475
