49 Users Online (48 Members):
Forums >> Revit Building >> Technical Support >> Compenent Placement - Issue
18 Posts No Rating |
I am trying to place a component I created as a rvt. file but somehow the family became a hosted component. Everytime I try to place it in the model it wants to be placed on a face of another object. When I try to place it without hosting it, it tells me to "switch to placement mode" which I don't know how. The only option I see is placing it in the workplane but this doesn't work as well since my workplane is constantly changing heights. Does anyone know how to switch a component to placement mode? The family was created as a casework and not wall or object based. I am using revit 2008. Thank you
You need to open the family and go to Setting-->Family Category and Parameters and uncheck the "Work Plane Based" box at the bottom of the dialog.
I just did this and have in the past but am getting an error on reload... I suspect theres not way to change the host type for instances already in my model? I have nearly 4000 instances I'd rather not have to go thru and replace....
Handrail Deletes when adjusting baluster placement? |
Tue, Aug 27, 2013 at 8:03:27 PM
Curtain Wall Door Placement Location |
Tue, Jul 26, 2016 at 7:52:26 AM
Family Placement issue |
Thu, Mar 27, 2008 at 4:02:27 PM
Wall Footing Issue with Placement |
Sun, Nov 21, 2010 at 9:22:07 AM
Outlet placement problems |
Wed, Jan 6, 2010 at 2:21:28 PM
Members: | 2000383 | Objects: | 22886 | Forum Posts: | 152181 | Job Listings: | 3 |
